hp tuners
If you don't know that, you should be learning rather than just trying to crank boost. Tuning is better started in other places than that. Go on HPT forums, find a good logging config you like, and get your base setup more accurate first. Then adjust boost a little bit, then timing and recheck fueling. Rinse and repeat.
If you aren't spending HOURS learning, you aren't doing it right. Learning to tune your car in 15 min will result in you blowing the car up. Happens all the time.
First if all, this is not my first rodeo. I am a nitrous guy and this is my first turbo car. I have read everywhere including this forum that you can turn the boost up to 20 psi with no other tuning. If that is not true then all you "genius's" that can't wait to hear about me blowing it up should enlighten the other idiots and tuners out there. That being said, if anyone can tell me what data line I need to change that would be great. Oh yeah, and if I do blow it up the last thing I would do is blame hpt or GM.
I usually go to straightline in New Lenox. this car is a lot more temperamental than the ls cars I'm used to. Just trying to get a little out of it.
One of your problems is you are in the wrong forum go to the hp tuners forum check into the lnf section
There are quite a few tables that need to work in conjunction with one another to produce accurate and safe boost consistently. This isn't dsmlink where you can just crank up one table, tweak the timing and maf scaling and basically be good to go.
Long and short of it, there isn't really a straight forward answer to your question without taking a lot of time to explain how and what tables needs to work together.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
