I don't understand what this code means?
Old May 24, 2010 | 08:56 PM
SaleenFreak's Avatar
hello I got both p0107 and p0100... I know that p0107 = map sensor. its been replaced.But what is po100. I found this===>MAF P0100 open circuit check sensor signal time period = 0 uS battery voltage > 10.5 V
Engine is running TRUE
Key on TRUE
but what does this mean? please help. My car symtoms are: itmakes 20psi but it does 15 a lag then the other 5
Old May 24, 2010 | 09:11 PM
rukkee's Avatar
Key on TRUE
P0100
The ECM detects that the MAF Sensor parameter is equal to 0 Hz for greater than 0.5 second.
Old May 24, 2010 | 09:23 PM
Originally Posted by rukkee
P0100
so in you honest opinion. how can i fix this. I traded my Maf with a ss sc and still the same code?
Old May 25, 2010 | 10:03 PM
now I have no boost.
Old May 25, 2010 | 10:22 PM
09CobaltSS1's Avatar
The maf from an LSJ will not work on the LNF. The frequency range is completely different
Old May 25, 2010 | 10:37 PM
Gabi's Avatar
wtf!! no comment
you know i know **** about that ****
hope you can fix it soon
Old May 25, 2010 | 11:44 PM
well I work on an autozone and for all cobalt I get the same part number maf. I was checking, could it be the sensor located on the cold pipe
(air charge sensor) that sensor could cause no boost.
Old May 26, 2010 | 12:28 AM
mmcgee123's Avatar
Le5 and the lnf are the same exact maf I kno cus I've swapped mine with my buddys
Old May 26, 2010 | 02:48 AM
pantherqs's Avatar
If you free-rev it at idle does it surge?
Old May 26, 2010 | 03:20 AM
SSlobalt's Avatar
MAF is the same as Z06 MAF.
Old May 27, 2010 | 05:15 PM
Well I traded the Maf from my Grandpas 05 ls sendan and still the same problem. I then took out the intake tube, cleaned it (it was full of grease type dirt) put it back on and the freaking cel went off. who knew. well anyway thanks for confirming that all mafs are the same.
bigdeertz
Nov 17, 2016 09:41 AM
ernnyyes
Oct 2, 2015 05:16 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
