i think the balt will have to go!
Once you get up to about 24 psi on the upgraded one, you still fall out of efficiency, plus, you are just stressing the turbo beyond what it needs to be stressed. Power is not made by psi. Power is made by flow. Psi is a restriction between the turbo and the head. This is why running larger IC pipes, bigger IC's, and less restricitve intakes can cause a slight drop in boost, because you are taking away the restriction. But, this drop in restriction and boost is not a drop in power, nor is it a drop in flow, it is only a drop in restriction.
So, the upgraded compressor wheel will allow enough flow over the top of the stock turbo, to put down about 40 more whp. Its rated at 40 lbs/min flow, vs the stock turbo which is about 36 lbs/min flow.
Vince can only send the initial tune, its up to the customer to log there vehicle and get fine tuned through Vince. I know I've seen about 2 or 3 posts were the person with a Trifecta tune never even sent logs back in for a fine tune (some of them were infiniboost
I wonder how many of these people are out there that never got fine tuned or logged a tune driving normally, not doing WOT pulls, then sending them in for a fine tune? I mean seriously I got tuned and fine tuned 3 times before having to send the cable back and I could have probably gotten 1 more in before having to send the cable back.
Also abusing your car when something else is wrong/broken with any of the tunes is going to break ****. It might happen sooner or later depending on the boost your running. Bottom line fix your **** if its broken or don't drive your car till its fixed.
But I do see why, America is the laziest county.
Now when you get a custom tune from a tuner, you get that personal feel.
Your right it's undeniable.........
Name the #1 Flaw of Americans right now? Or should I say what American's are known to the best at?
What is that associated with?
If you don't use notes for a test, when allowed, and fail do you wonder why?
That's right sarcasm is a second language to me.
Then you had a great day!!!!!
Last edited by crypticscifer; Mar 24, 2010 at 05:36 PM. Reason: Automerged Doublepost
Again, I said I'm not hating on Vince's tunes or his capabilities.
Ask any HPTuner that runs the pill mod, you hit the nail on the head, these guys running the pill mods are the tuners and not selling a tune + pill mod.
I bet you couldn't get a tuner running the pill mod to sign off on their name and install the mod + tune.
You defend Vince because you sell his tune, and I understand and appreciate that.
I'm not bashing him, I just don't agree with some of his methods that's all. And this being the great country it is, I can.
If I let them know the dangers and they are willing to accept them and proceed, sure why not. BUT, this is a tune I ran on my own car and perfected over miles to be sure it wouldn't damage their car. Not saying Vince doesnt do that, just saying I dont tune blindly or take chances with someone else's car. I take them on my own first
Ah so yours is not an out of the box tune, it's custom with a base tune of yours and tweaks for the car installed on.
Nothing wrong there. Feels good knowing it will work.
Nelson, after you install the Infiniboost tune, are you able to tweak for mods and other environment factors?
If you're refering to Vince "blindly" tuning that'd be completely wrong. Vince owns a HHR SS, same LNF motor, and he runs all of his tunes and does all of the "experiments" (if you will) on it way before anyone gets a tune from him. So in that case Vince does the same thing as you do. For example, Vince had run a 30psi tune on his HHR for a while to see how it ran, pros and cons of that amount of boost, etc. He should have an article out soon addressing many different views that have been illistrated on here with dyno-backed evidence on each to prove/disprove information. But as in all sitations, both sides of the story need to be told. I appreciate your professionalism when it comes to these things and I respect you for it just as when you were humble about the race between your car and the Trifecta tuned car.
Yes you can have the tune updated for mods. Like the others have stated, Vince sends an initial tune and in order to be fine tuned, datalogs must be sent to him so that he can view the information collected. For example, if you have a CAI, your a/f ratios won't be dead on with out a tune... through a simple datalog, Vince can view what your car is specificially dealing with and can adjust through updated tunes. Like in all science, the more data provided allows for better understanding and adjustment of variables to achieve the greatest possible outcome.
I meant nothing like that. I just meant I don't throw something in someone's car that Im not familiar with, and 30psi would be just that. Im not trying to take any stab at him at all here. I have read the whole thing on the infiniboost and saw people posting lil tidbits here or there about taking rides in his HHR at that level before it ever came out.
And I have shown dyno's comparing 22 psi to 30 psi on my car. 22 psi numbers were 311/356, 30 psi numbers were 321/392. The car made almost 50whp more thru the midrange as well running the 30psi tune. I can post the dyno again if you'd like.
pretty much what you should do is buy a 500-1000 dollar beater civic. Buy some pistons and go from there, do some work yourself, and see if you can find a mechanic that can help with the tricky stuff. I dont think the motor has to leave the car?
i cant... too much $... i already spend all my savings in buying pistons, ARP head studs and Cometic head gasket... plus the installation that joe will do...
i also just found out that by TTR (which i place the order from them) dont have the pistons in stock and i have to wait till next week to get them shipped :@
Gotta Pay to play. Lots of cylinder pressure and heat will take a motor out eventually.
Wait didn't you post a thread saying you would buy the pistons right now, then someone posted and you never replied.
Why don't you go see if they still have them.
i know... well too late for me i guess...i kind of look at it at a good way that i blew my pistons.... now when i get my big turbo set-up (very soon) im going to be able to run very high#'s since i changed my freaking pistons already!
And you say this based on what? And use YOUR words, don't quote someone else...
