IC install issues
Old May 25, 2011 | 07:18 AM
nolimits's Avatar
IC install issues
Just installed my new Treadstone tr8 IC and fittment was excellent and it looked superb....BUT where the coupler off the elbow meets the hot side charge pipe it seems to be very weak and flimsy, can not get the charge pipe to stay on and eventried eliminating the coupler in between the elbow and the charge pipebut it still blew off.Is my only solution to add a steel or aluminum joiner in between the coupler and CP?
Old May 25, 2011 | 09:01 AM
CudaJoe's Avatar
If you have a stock hotside charge pipe, the stock coupler is a real bitch to get on and stay on. You gotta have some serious manpower to put it on good and tighten the T-Bolt as much as possible. I had it blow off once. I made sure it would not blow off again. TR8 is a decent IC, I have it too
Old May 25, 2011 | 09:08 AM
nolimits's Avatar
Yeah I noticed the stock coupler does not want to work well with the coupler I recieved with the IC .... I was just thinking of adding some aluminum in there to support the stock coupler atleast untill I can upgrad the charge pipe.
Old May 25, 2011 | 09:25 AM
umrdyldo's Avatar
pretty sure treadstone even said the stock charge pipe would be a little tough to do on their IC.
Most people should have gone with their pipes and IC as a kit.
Old May 25, 2011 | 09:48 AM
Supercharged Guy's Avatar
Yeah, you should just get their CP's too so that you don't have to mod your stock ones up
Old May 25, 2011 | 09:55 AM
dthomp2366's Avatar
I got mine on by taking the "elbow" out of the intercooler and putting that in the stock lower coupler as far as possible using rubbing alcohol as a lubricant but I flared the end of my "elbow" to make sure it couldn't blow off again. I used a deep socket and rachet and went to town on it. No problems since but mine blew off about 6 times before I added the flare.
Old May 25, 2011 | 10:35 AM
ATLsilverSS's Avatar
i just installed a tr10 on my hhr and had no issues with connecting to the stock piping....although i had to make several other mods to the crash bar and supplied mounting hardware to make it fit on the hhr due to the radiator being different than the cobalt. i used a spray lubricant to get the supplied elbows onto the stock couplers...tightened the livin **** out of them and no problems so far.
Old May 25, 2011 | 10:43 AM
Treadstone's Avatar
yea, if you want, we have the charge pipes that go along with this kit and will bolt up no problem with the TR8 beta kit
~jason
Old May 25, 2011 | 10:46 AM
ssblackstealth's Avatar
corn gas ftw....
the stock pipes are terrible anyways....just save up for the hard pipes, they are deff worth it and look great too
Old May 25, 2011 | 10:47 AM
Tgustafsonjr's Avatar
I'd just get their pipes. Fitment is amazing and they look really good.
Old May 25, 2011 | 09:53 PM
nolimits's Avatar
After test number?4 with hairspray and some elbow grease the stock CP is holding so far.... atleast untill the wifey lets me get the hardpipes from treadstone.
Old May 25, 2011 | 10:35 PM
SSlobalt's Avatar
You oculda just bought the ZZP IC and installed it without buying aftermarket charge pipes and had perfect fitament.
Old May 25, 2011 | 10:55 PM
Dart_SI's Avatar
^ and a lower than stock intercooler that you might have to worry about if you hit a big bump. im already glad i installed a tr8 because if i had a zzp it would have been damamged by now.
Old May 25, 2011 | 11:04 PM
DirtyBalt09's Avatar
Is ZZP the only one with upper charge pipe that bolts to stock location fastener on top of engine.
Old May 26, 2011 | 12:15 AM
SSlobalt's Avatar
No. There are others that bolt there. Injen does. I know Hahn doesn't.
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
