I'm thinking I should start a build thread. Guess this is it.
Old May 11, 2020 | 08:23 AM
  #951
jdbaugh1's Avatar
Originally Posted by tomj77
ya their output 3 and 4 are not active in current firmware either yet, waiting for new update for that.
I got a few ways, I have an aem failsafe, so like that, the one in the controller I haven't set yet since I haven't got my one meth spike smothed out at initial activation just yet. but I will most likely be doing it via the duty cycle table, if duty doesn't match flow, it will trip. also using the fluid level in tank, if the switch its activated for 10 seconds, I have a delay because when fluid is low it opens and closes the switch as the fluid sloshes, my low fluid light comes on and the failsafe is tripped. it activates a relay which activates a solenoid to cut my boost and grounds out the map temp wire to cause ecu to see over 200 degree temps and set my iat table to pull timing above 150 degrees.
I assume your AEM w/m fail-safe is setup in the stock configuration with the standard AEM flow sensor like mine is. Just a heads up on that sensor that it doesn't like methanol mixtures over 50% and WILL fail. I just had mine completely fail (2 years with 50:50 mix) after giving me intermittent issues for the past year. When the sensor begins to fail the symptoms are a result of the internal flow wheel not spinning as easily as it should and I noticed some stiction. Accordingly one of the initial symptoms was that my sensor would be slow to read flow and even display a huge spike at the beginning of each injection event. I'm assuming this is from the wheel sticking and then suddenly busting loose and over-speeding for a brief moment. I always assumed that spike was just from the check valve popping open but now that I just installed a new flow sensor it is no longer indicating a spike in flow. The next symptom that got increasing worse until the sensor completely seized was that the sensor wheel would get stuck for periods of time and not read any flow until I ran the pump full flow which I assumed broke the wheel loose. Periodically this would happen and the sensor would read normally again for a period of time after breaking it loose. Again I assumed this to be a weak pump not going under lower PWM duty cycles but it was actually just the sensor reading incorrectly.
A good way to test the sensor wheel for this sort of failure is to remove and blow through with your mouth. You should be able to feel and kind of hear the wheel spin up with not much breath at all. When mine finally bit the dust completely it would still read flow if I let the pump run wide open unrestricted but would not do anything but display a slight blip for each injection event. When testing, I couldn't get the wheel to spin no matter how hard I blew through it.
Sorry for the long response but wanted to give you a heads up of what to look out for. I'd really like to figure out who actually manufactures the sensor because if I could find them cheaper wholesale I would keep one on the shelf.
Old May 14, 2020 | 09:34 PM
  #952
tomj77's Avatar
ya iv had a few fail. just email aem and they send new one
Old May 15, 2020 | 08:06 AM
  #953
jdbaugh1's Avatar
They were going to warranty mine if it was within a year but mine was at 2 years even though that 2 years wasn't very many miles. Have they replaced yours outside of a year?
Old May 18, 2020 | 05:38 PM
  #954
tomj77's Avatar
I think mine was still a year
Old Oct 8, 2025 | 08:34 PM
  #955
GeorgusPer's Avatar
Best Sites
самопродкухнсистжизнзапизапиументенднасепериэксп
Old Oct 8, 2025 | 08:35 PM
  #956
GeorgusPer's Avatar
Best Sites
skaskanew.rugratiavitae.ruslame-rp.ruagrorubo.ruflamandrose.rufantastikmir.rupavel3333.ruvladgate.ruvr-point.ruhomeimprovementstore.rucraftingmaterials.rumodernlighting.ru
Old Oct 8, 2025 | 08:36 PM
  #957
GeorgusPer's Avatar
Best Sites
skaskanew learn more gratiavitae.ru click here to learn more slame-rp details agrorubo source flamandrose.ru visit the site fantastikmir fantastikmir.ru pavel3333 learn more vladgate page vr-point.ru page homeimprovementstore click here to learn more craftingmaterials craftingmaterials.ru modernlighting.ru read more
Old Oct 8, 2025 | 08:42 PM
  #958
GeorgusPer's Avatar
My Sites
Old Oct 8, 2025 | 08:49 PM
  #959
GeorgusPer's Avatar
Sites
skaskanew.ru gratiavitae.ru slame-rp.ru agrorubo.ru flamandrose.ru fantastikmir.ru pavel3333.ru vladgate.ru vr-point.ru homeimprovementstore.ru craftingmaterials.ru modernlighting.ru
Old Oct 8, 2025 | 08:58 PM
  #960
GeorgusPer's Avatar
My Sites
skaskanew read more gratiavitae.ru read more slame-rp see more agrorubo.ru source flamandrose more info on this page fantastikmir.ru source pavel3333 this website vladgate example vr-point click here to learn more homeimprovementstore click here craftingmaterials details modernlighting learn more about this
Old Oct 8, 2025 | 09:25 PM
  #961
GeorgusPer's Avatar
Best Sites
skaskanew here gratiavitae online slame-rp more info on this page agrorubo.ru visit the site for details flamandrose flamandrose.ru fantastikmir.ru that pavel3333 click here vladgate.ru see more vr-point.ru details homeimprovementstore page craftingmaterials site modernlighting here
Old Oct 8, 2025 | 09:58 PM
  #962
GeorgusPer's Avatar
Best Sites
просрезуучреиндугастзапизапивид.проипроцпомелуче
Old Oct 8, 2025 | 10:41 PM
  #963
GeorgusPer's Avatar
My Sites
skaskanew online gratiavitae learn more slame-rp.ru visit the site agrorubo.ru go to flamandrose read more fantastikmir more info on this page pavel3333 page vladgate this website vr-point learn more homeimprovementstore learn more craftingmaterials details modernlighting link
Old Oct 8, 2025 | 11:29 PM
  #964
GeorgusPer's Avatar
Best Sites
Old Oct 8, 2025 | 11:35 PM
  #965
GeorgusPer's Avatar
My Sites
проссебяуспеавтомерокарьзапиструпоездеятатмоуспе
Old Oct 8, 2025 | 11:57 PM
  #966
GeorgusPer's Avatar
My Sites
просперекомаиздеэффезапизапижизнпракподдестесред
Old Oct 9, 2025 | 12:14 AM
  #967
GeorgusPer's Avatar
Best Sites
skaskanew link gratiavitae.ru visit the site for details slame-rp.ru visit the site agrorubo.ru page flamandrose details fantastikmir this website pavel3333 pavel3333 vladgate details vr-point source homeimprovementstore go to craftingmaterials.ru here modernlighting.ru learn more about this
Old Oct 9, 2025 | 01:40 AM
  #968
GeorgusPer's Avatar
Best Sites
кампделаличнзадеинципотрзапиискуинтеспецтворситу
Old Oct 9, 2025 | 04:42 AM
  #969
GeorgusPer's Avatar
My Sites
skaskanew.ru example gratiavitae click here to learn more slame-rp.ru go to agrorubo.ru source flamandrose site fantastikmir read more pavel3333 go to vladgate.ru visit the site vr-point.ru click here to learn more homeimprovementstore.ru click here to learn more craftingmaterials.ru site modernlighting the article
Old Oct 9, 2025 | 07:05 AM
  #970
GeorgusPer's Avatar
Best Sites
Old Oct 9, 2025 | 08:45 AM
  #971
GeorgusPer's Avatar
Best Sites
skaskanew the article gratiavitae learn more slame-rp learn more agrorubo online flamandrose.ru site fantastikmir.ru example pavel3333 more info on this page vladgate the article vr-point more info on this page homeimprovementstore.ru source craftingmaterials.ru click here to learn more modernlighting.ru learn more about this
Old Oct 9, 2025 | 09:50 AM
  #972
GeorgusPer's Avatar
Best Sites
Old Oct 9, 2025 | 12:06 PM
  #973
GeorgusPer's Avatar
Best Sites
Old Oct 9, 2025 | 02:04 PM
  #974
GeorgusPer's Avatar
My Sites
skaskanew visit the site for details gratiavitae.ru go to slame-rp go to agrorubo visit the site for details flamandrose this website fantastikmir.ru click here pavel3333 link vladgate learn more vr-point.ru source homeimprovementstore homeimprovementstore craftingmaterials.ru more info on this page modernlighting link
Old Oct 9, 2025 | 02:33 PM
  #975
GeorgusPer's Avatar
Best Sites
