I'm thinking I should start a build thread. Guess this is it.
Old Apr 1, 2018 | 09:09 PM
  #701
tomj77's Avatar
freaking beautiful.
Old Apr 1, 2018 | 09:11 PM
  #702
tomj77's Avatar
I got my parts, spent all long weekend getting everything back together. few more hours to go to get it running. trans is in....took me and bro in law 3 hours to get it on. we had difficulties lol. its all full of oil and ready to rock.
I got 6 gears
Old Apr 1, 2018 | 10:00 PM
  #703
63 Nova SS's Avatar
Awsome! Can't wait to hear how well you like it.
Old Apr 3, 2018 | 11:05 PM
  #704
tomj77's Avatar
Old Apr 3, 2018 | 11:07 PM
  #705
tomj77's Avatar
Got new recirc downpipe on. Not the funnest thing to do. Had to take out the rear trans mount through bolt and heat sheild to get it in. Put bolt back but left heat sheild off. No need for it really. Should get it started by the weekend.
Old Apr 4, 2018 | 10:45 PM
  #706
tomj77's Avatar
So I'm just gonna do a quick list of all the new stuff I put in the car this winter while waiting for trans.
2 new brake lines cause I damaged the 2 front ones are going in tomorrow.
all 4 wheel bearings - timkin
new recirc downpipe I had to modify it.
new style zzp turbo manifold. very nice manifold and is 1.5 pounds lighter than old style.
I swapped out my pile of trash devils own braided stainless meth line for a prometh braided stainless meth line that does not have the steel ends to rust on me.
new ottp throttle body spacer. went fill an4 all the way. installed a solenoid just before the nozzle so no syphoning. there is also a check valve for extra protection.
I ported my intake manifold to match gasket.
all new boost, batt, egt, and water temp autometer pro spek gauges. these things are very cool. love them. nice and simple and clear to read. with peak, low and high warning, and 7 colors. gauges go red when you hit high warning. pretty sweet.
new battery cause mine died.
new f35 6 speed built quaife trans from Jason. which works in first gear and reverse for sure, only 2 I tried while cars in the air lol.
exedy hyper single clutch with lighter Chromalloy flywheel. thing revs pretty quick compared to stock.
idk if I'm forgetting anything, ill probably do a walk around and post vid when I'm done.
of yes and I also threw on a wingless truck lid. looks sexy.
I'm still waiting for those redesigned zzp coil packs and also have all the parts for retrofit project which I will be starting once the car is done here in a few weeks.
Old Apr 4, 2018 | 11:34 PM
  #707
Damn man lots of work for sure can't wait to see it running in those vids
Old Apr 5, 2018 | 07:42 AM
  #708
tomj77's Avatar
Well she is running. Had it running for 15 minutes yesterday to let the trans get itself all lubed up in first gear. Idk why so many guys always have issues after they do work getting their cars running, mine purs like a wild beast lol. Just gotta check for leaks, throw on the replacment brake lines, rear wheel bearings and wire up my meth solinoid and she good.
I also dont get how people have so much trouble bleeding the clutch. I didnt even bleed mine and it feels great. Filled tob before install and sealed off pipe faceing up but still could push fluid out when trans was unstalled. Then i let my line gravity bleed till fluid came out and quickly hooked it up. Had 0 issues. May still bleed a peddlw push or 2 but as is it feels perfect.2
Old Apr 5, 2018 | 01:02 PM
  #709
tomj77's Avatar
Oh yes i also upgraded to a 10gph meth nozzle. Spraying 1000cc
Old Apr 5, 2018 | 01:05 PM
  #710
So you're spraying the meth into the spacer instead of the chargepipe?
Old Apr 5, 2018 | 07:57 PM
  #711
TurboTechRacing's Avatar
Looking good!
Old Apr 5, 2018 | 08:01 PM
  #712
63 Nova SS's Avatar
Thing ought to scream, and hold together.
Old Apr 6, 2018 | 06:03 AM
  #713
tomj77's Avatar
yes i cant spray into charge pipe due to maf relocate
Old Apr 6, 2018 | 01:16 PM
  #714
tomj77's Avatar
Old Apr 6, 2018 | 01:42 PM
  #715
True you had to run a bov for your set up
Old Apr 6, 2018 | 07:21 PM
  #716
tomj77's Avatar
i think a little down the road ill get moyer to make me a cp that will be able to be sprayed into. Just move maf close to ic
Old Apr 6, 2018 | 10:28 PM
  #717
I need to get mine installed well Idk if I'm even going to run it anymore
Old Apr 6, 2018 | 11:11 PM
  #718
tomj77's Avatar
what your bov?
Old Apr 6, 2018 | 11:20 PM
  #719
The meth kit
Old Apr 14, 2018 | 08:05 PM
  #720
tomj77's Avatar
Some racecar sounds with the new trans
Old Apr 14, 2018 | 08:06 PM
  #721
tomj77's Avatar
first video I accidently went from 5th to 4th lol still getting used to 6th gear
Old Apr 15, 2018 | 06:39 AM
  #722
63 Nova SS's Avatar
Sounds good. Has a bit of wine to it?
Old Apr 15, 2018 | 10:03 AM
  #723
tomj77's Avatar
you didnt hear it? Listen carefully lol
Old Apr 15, 2018 | 01:30 PM
  #724
Def sounds good I got some goodies I'm going to install on mine
Old Apr 19, 2018 | 10:06 PM
  #725
tomj77's Avatar
Cobalt SS Build List
Engine
• Semi Closed Deck LDK Block
• Stock Crank
• 4340 Forged Connecting Rods
• Wiseco Forged Aluminum 86mm Pistons
• Neutral Balance Shafts
• Ati SuperDamper (Underdrive)
• Ported LNF Head
• ARP Head Studs
• Stage 2 Comp Cams With Big Fuel Lobe (224 int duration .438" int lift 218 exh duration .420" exh lift)
• 82# Ecotec Valve Springs & Titanium Retainers
• Ecotec Viton Valve Seals
• Opel Upgraded Direct Fuel Injectors
• Ported Stock Intake Manifold
• Ported ZZP Stainless Steel Exhaust Manifold With 38mm WG Port
• BorgWarner S257 SXE Turbocharger With Stainless Steel Turbine Housing (30.5 Psi Boost Pressure)
• Custom Powell Stainless Turbo Brace
• 3” ZZP Down Pipe With Recirculated WG Dump Tube
• Hahn Racecraft 3” Megnaflow Exhaust
• 38 MM Water Cooled Tial Wastegate
• Tial 50 MM Bov
• ZZP Intercooler
• ZZP Hot/Cold Side Charge Pipe
• ZZP 3.5” Intake
• Powell Air/Oil Seperator
• Snow Performance 1000CC Water/Methanol Injection System With 9L Tank And Failsafe System
• ZZP Upgraded Radiator
Transmission
• B3Design Custom Built F35 6 Speed
• Quaife Semi Straight Cut Gears
• WPC Treated Bearings
• Polished Gear Set
• B3Design Case Bracing
• GM Limited Slip Diff
• 4.05 Final Drive
• ARP Bolts And Fasteners
• Exedy Hyper Single Clutch With Lightened Chromalloy Flywheel
• Ottp Short Shifter
• Koni Adjustable Struts And Shocks
• Powell YYZ v5 Springs
• Powell Solid Control Arm Bushings
• Power Grid Stainless Steel End Links
• Powell Hardcore Rear Sway Bar
• Timkin Wheel Bearings
Interior
• Custom Dash With 3 Pod Gauge Pod
• 3 Aeroforce Interceptor Gauges
• Aem Water/Methanol Failsafe Gauge
• Autometer Pro Spek Water Temp Guage
• Autometer Pro Spek EGT Gauge
• Autometer Pro Spek Volt Gauge
• Autometer Pro Spek Boost Gauge
