I'm thinking I should start a build thread. Guess this is it.
Old Aug 3, 2018 | 02:42 PM
  #776
tomj77's Avatar
Originally Posted by jdbaugh1
You mind expanding on this a bit? I once went for a dyno run on a loaded mustang dyno and the readings were weird for my setup. My torque peaked and died off way earlier than would be expected. We could have been a little off when we calibrated the dyno to engine rpm and I don't know if that by itself could have caused it or not. But you sound like you're familiar with dyno's reading funny so I wondered if you kind of knew what all could cause that to happen.
guys who use that dyno who own cobalts keep saying that they have a hard time getting a tach signal so it reads stupid low or something. Like guys who dyno 480 on one will dyno like 320 on that one. So idk I'll have to ask them and find out for sure. The other place finally emailed so I'll see if I dont go there instead
Old Aug 3, 2018 | 02:45 PM
  #777
jdbaugh1's Avatar
Interesting. When I dyno'd there was no direct tach signal he just had me try and hold a constant RPM on the dyno to calibrate the machine. I had a hard time holding it steady and I am betting that is where things went wrong.
Old Aug 3, 2018 | 10:59 PM
  #778
tomj77's Avatar
well I talked to the guy and he said because it was dyno day its all kinda rushed so that could have been why there were problems. Really no time to get it right if something doesnt work
Old Aug 5, 2018 | 01:39 AM
  #779
tomj77's Avatar
Light glare screwing up pic but I couldn't get better shot. All sealed up. Just gotta install
Old Aug 5, 2018 | 08:16 AM
  #780
jdbaugh1's Avatar
Wait, you talked to the guy who did my dyno?
Btw, lights look awesome.
Old Aug 5, 2018 | 04:18 PM
  #781
tomj77's Avatar
I talked to guy at the dyno place that has tach issues . idk who ur guy is
Old Aug 6, 2018 | 06:31 AM
  #782
jdbaugh1's Avatar
You just described my situation perfectly though with it being dyno-day and not having enough time to look into it lol because that is exactly what my guy told me. I was like how the hell did you track him down.
Old Aug 7, 2018 | 08:42 PM
  #783
Bluelightning's Avatar
Got Bewst?
No. Hp will read fine at Speed Factor. You will just have no tq reading or the tq curve will be will look nuts if the tach signal acts up.
Old Aug 7, 2018 | 09:20 PM
  #784
63 Nova SS's Avatar
Yep, that's what happened to me on the first pull when I dynod the first time. We found the right wire though and were good from there.
Old Aug 7, 2018 | 09:37 PM
  #785
slapbetcommissioner's Avatar
For mine it was reading half rpm and disnt even produce a torque figure
Old Aug 7, 2018 | 10:57 PM
  #786
Horsepower was bang on it just showed it at the wrong rpm range.
Old Aug 8, 2018 | 12:46 AM
  #787
tomj77's Avatar
well then I guess ill go there after all. we got time to find the correct wire.
Old Aug 8, 2018 | 06:06 AM
  #788
63 Nova SS's Avatar
Tom- we just partially untaped one of the coil wires and used that. Worked fine.
Old Aug 8, 2018 | 02:28 PM
  #789
tomj77's Avatar
To bad its not like the sunfires. They had a rpm signal at one of the fuse box terminals
Old Aug 9, 2018 | 11:31 AM
  #790
tomj77's Avatar
Does speed factor dyno read stupid low tq or what? 353 wheel tq. That dont seem right
Old Aug 9, 2018 | 08:44 PM
  #791
63 Nova SS's Avatar
You have way more than that
Old Aug 10, 2018 | 12:48 AM
  #792
tomj77's Avatar
ya I think so. ill goto other dyno next time
Old Aug 10, 2018 | 12:50 AM
  #793
tomj77's Avatar
Old Aug 10, 2018 | 05:54 AM
  #794
63 Nova SS's Avatar
It's not reading/converting torque correctly on that sheet. Your hp never slows down, bet that thing pulls hard.
Old Aug 11, 2018 | 04:15 PM
  #795
tomj77's Avatar
I agree. I ran my log through virtual dyno and my tq was like 525. Not that that program is at all accurate lol
Old Aug 11, 2018 | 07:45 PM
  #796
Got Bewst?
All depends on how the signal is reading. Which you can see pretty fast looking at the tq curve on your graph if it’s stable or not. Looks smooth and reading right to me.
Try motion.
Old Aug 11, 2018 | 10:59 PM
  #797
tomj77's Avatar
Try motion.
ya I will for comparison . u had low tq numbers as well on this turbo right?
Old Aug 12, 2018 | 01:12 PM
  #798
Got Bewst?
I did but it’s to be expected on a big turbo lsj set up. LNF is a different story though.
Old Aug 12, 2018 | 07:46 PM
  #799
tomj77's Avatar
man got a good scare today. driving home and my car looses power and just shut off. oil light goes on...which freaked me out but didn't realize car had shut down. so I look under the car and I thought I saw dripping..checked oil level. nothing on there. called my dad to tow me home . looked under, nothing. no oil, no wet spot nothing at all. so I go to drain it, I was missing about a liter of oil, which id expect with this build and the 100+ hard pulls iv done already in the last 3 months. time to change oil anyway. so I put oil back in to do some tests until I can get new stuff. car would crank but no start. checked codes. fuel injector codes. cleared them....nothing. checked ground, nothing. pumped the gas and it fired for a sec then just cranked again. so I pulled the injector plug, pushed it in as hard as I could so it felt nice and snug, cleared codes again....now I had a fuel pressure code as well, and she started up. relief. guess the injector harness wasn't clicked in and slowly came loose. my trims and idle seem to be a lot better now as well.....will check some more after I do oil change.
Old Aug 12, 2018 | 08:27 PM
  #800
I've had that happen to my car where it just shuts off and the oil light comes up it's weird because in just driving normally
