I'm thinking I should start a build thread. Guess this is it.
Old Aug 12, 2018 | 09:43 PM
  #801
63 Nova SS's Avatar
Thankfully that hasn't happened to me yet. I bet your heart sank when it first did it.
Old Aug 12, 2018 | 11:17 PM
  #802
tomj77's Avatar
Ya i was driving 90....thats 50mph . i did drive onto the shoulder for a sec cause i was looking elsewhere lol right after the bump cause it was like a 2 inch drop it happened. Yes i was scared. Thank God it was nothing
Old Aug 15, 2018 | 09:58 PM
  #803
tomj77's Avatar
little 70 to 150 pull. id have done 60 but I wasn't paying attention
Old Aug 16, 2018 | 05:55 AM
  #804
63 Nova SS's Avatar
Nice! Kind of think it's weird when you first hit it and it goes from 2500-5,000 instantly but I don't hear any spin? Tach reading slow?
Old Aug 16, 2018 | 10:25 AM
  #805
ProfDNS's Avatar
Nice vid! Are you using a GoPro and just sticking it just inside the steering column or you have a different setup?
Old Aug 16, 2018 | 10:27 AM
  #806
T-Man's Avatar
Sounds like he blips the throttle, drops into 3rd and then goes WOT.
Car runs hard Tom!
Old Aug 16, 2018 | 01:30 PM
  #807
tomj77's Avatar
Ya I blipped it and its a lighter fw so it revs up quick. I didnt get wheel spin it was too warm and only 12 degrees timing so didnt make full power. If it would have been 5 degrees cooler id gave spun.
And yes I got a go pro . stuck it to column
Old Sep 9, 2018 | 10:17 PM
  #808
tomj77's Avatar
So...updates. Thanks to Jason, who discovered the powell v3 setup does not work properly with a big turbo setup, I checked my setup and and sure enough at idle the turbo doesn't create enough vacuum to vent the crank case, so u have pressure at idle, which is why I burned oil since last change. my separator itself had a bad seal and just looked like crap so I put a spare one in. I am working on a solution to this issue, im gonna try it out and let u guys know how it works.
also Im getting some ethanol this next week so I will be doing an e30 or 40 tune soon.
Old Sep 9, 2018 | 11:58 PM
  #809
Well that's no good news since I'm planning on getting a v3 separator soon
Old Sep 10, 2018 | 06:07 AM
  #810
63 Nova SS's Avatar
Powell should come up with a solution. Wonder if Adrian is aware of this?
E30 or 40 will really help.
Old Sep 11, 2018 | 06:40 PM
  #811
tomj77's Avatar
I'll be working on a solution. If it works I'll let you know.....can easily build ur own then. Jason is also testing something. I'll let him share if he wants. I'm just waiting for parts to test my idea. If it works....ill do a permanent fix if not....ill let u know then lol
Old Sep 11, 2018 | 07:21 PM
  #812
Yes please do I dont wanna spend 700 bucks and for it not o work properly
Old Sep 11, 2018 | 10:05 PM
  #813
zeeky420's Avatar
Go e30
Old Sep 11, 2018 | 10:43 PM
  #814
tomj77's Avatar
Originally Posted by zeeky420
Go e30
thats what I'm doing
Old Sep 16, 2018 | 01:22 PM
  #815
tomj77's Avatar
ok so I discovered an issue with the ati super damper underdrive pulley for our car. seems like it underdrives the alternator a little to much. 12 % to be exact.. this is fine when ur not using ac, u get about 14v....which sometimes drops a little and im sure is the reason I keep getting random knock. but once u use ac, volts drop to 13.5 and I get **** tons of knock especially at low speed driving. like up to 10 degrees on light throttle. this goes away as soon as ac is turned off. so I need a solution to this. anyone know of an alternator overdrive pulley that will do around 12 percent or something that will fix this?
Old Sep 16, 2018 | 03:43 PM
  #816
zeeky420's Avatar
Take ac out of car problem solved
Old Sep 17, 2018 | 01:26 PM
  #817
tomj77's Avatar
ya no. That wont really help the issue. If fans come on from warm coolant it will do same thing.
Old Sep 17, 2018 | 01:27 PM
  #818
tomj77's Avatar
I found a high output alt with a .2 inch smaller pulley that should work ....just costs alot
Old Sep 17, 2018 | 09:38 PM
  #819
63 Nova SS's Avatar
Does our alternator have a press on pulley? If so you could swap that out. Never had one apart on the cobalt. Used to do those things a lot on small block chevys.
Old Oct 22, 2018 | 10:43 PM
  #820
tomj77's Avatar
My new mishimoto catch cans and setup....no more crank case pressure at idle boys. Still gotta test while driving but should work fine.
Old Oct 22, 2018 | 10:50 PM
  #821
63 Nova SS's Avatar
You gonna set it up similar to the 2.0 in the ats?
Old Oct 22, 2018 | 11:51 PM
  #822
Fancy! I'm going to need that for sure
Old Oct 23, 2018 | 06:52 AM
  #823
tomj77's Avatar
no clue how that is
Old Oct 26, 2018 | 01:44 PM
  #824
tomj77's Avatar
Little update. System did not work as it is. Got tons of crank case pressure after car was warm. Based on mine and mr jasons trials it seems with heavy mods like we have you have to either heavily mod the pcv system.....ill see if Jason wants to share what he did. Or run a oil cap vent along with the dual cans. I'm gonna try bigger ports first but thats what its looking like it will be in the end
Old Oct 26, 2018 | 02:00 PM
  #825
Tom do you think that I would need that I'm pretty much FBO with ZFR and running e47 maybe one day I'll do e85
