injen charge pipes
Old Jun 28, 2011 | 11:56 AM
RomeDiggy's Avatar
injen charge pipes
Does the lower piece of the charge pipe connect to the intercooler or the rubber hose that connects to the intercooler. I was thinking about buying this charge pipe and was wondering how it connects.
Old Jun 28, 2011 | 11:58 AM
09CobaltSS1's Avatar
it connects directly to the intercooler inlet endtank
Old Jun 28, 2011 | 12:01 PM
SeanEE89's Avatar
Injen doesn't offer a solution for the piece that goes from the intercooler to the intake manifold. Just the piece that goes from the turbo to the intercooler. In all honesty though there's no need to replace the lower charge pipe. It's not like anyone is ever going to see it and the lower charge pipe is an adequate enough piece.
Old Jun 28, 2011 | 12:08 PM
The Injen hotside pipe is a 2 piece turbo side assembly. He is refering to the lower piece that attaches to the IC and whether or not it attaches directly to the endtake or if the stock flex piece is used.. That is at least how I am understanding his question.
Old Jun 28, 2011 | 03:42 PM
RomeDiggy's Avatar
You are right, that is what I'm talking about. Thanks by the way. The pics of the pipes that I have seen of the lower hot side just didnt look long enough, but I guess it is
Old Jun 28, 2011 | 03:48 PM
Sweetsandman's Avatar
This.
And some people say that the couplers are a bit short. I disagree with that. I mean sure, they could be longer, but they fit without any issues and hold no problem.
Old Jun 28, 2011 | 04:14 PM
BPacak's Avatar
Vtec Rep
I love mine, yeah you dont need the upgraded couplers but i got them anyways makes it easier and a better chance of the pipes not blowing off.
Old Jun 29, 2011 | 09:39 AM
RomeDiggy's Avatar
Looks good! Pretty easy install? You don't have to take the bumper off do you?
Old Jun 29, 2011 | 10:28 AM
Very easy install, and no the bumper does not need to be removed. The fact that you'll probably have a harder time removing the stock charge pipe than you will installing the Injen pipe should give you a basic idea of how easy of an install this will be.
Old Jun 29, 2011 | 10:39 AM
MastaShaKe_88's Avatar
you don't have to take the bumper off.. but gettin the lower part of the stock pipe off without a ramp/lift/jack is a biiiiiiiiiiiiiiiiiitch.. trust me...
Old Jun 29, 2011 | 10:46 AM
FasterIsBetter's Avatar
Just to give you an idea, I had someone helping me so we could get done quick and right. I got mine done in 10 minutes. Would take 20 minutes tops to install. Just make sure you tighten the clamps with a ratchet and not a screwdriver otherwise your pipes will pop off and I think that's the main reason most people's slide off. And on the lower one, try to slide most of the coupler towards the intercooler. the lip for the clamp to catch on is a bit farther back on the intercooler than on the charge pipes.
Old Jun 29, 2011 | 10:57 AM
OBZ's Avatar
OBZ
Use hairspray helps lube to get it on, and when it dries it helps hold like glue
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
