installing MPX catless downpipe, NEED HELP
im trying to figure out if i can reuse the exaust gaskets from the stock exaust,
I dont wanna pull this crap off again.
So has anyone reused it with out any problems
i reused mine, but i only had 4k miles on my car when i did, im sure it will be fine just be careful when taking it apart and what not, if u dont feel comfortable reusing it, just buy a new one and install it lol
haha ya it is, only prob i had was the damn bolt on top of the triangle were it connects to the catback, had to undo a hangar to lower it enough to get to it, i did my whole dp install in like 30 min with a lift and power tools
haha ya mine was easy to un screw but trying to get it off the dp with it still on the car was a whole nother story haha(i wasnt too bright when i did it, should have took the dp off first :p)
Never had too much problem with O2 sensors, spray the joint with PB Blaster or similar penetrating oil (not WD-40, nowhere near good enough), and try to use a good flare wrench to take it out. Also, try with the exhaust slightly warm if you are still having problems.
I reused mine...twice...with zero issues (Once when I put my ZZP on, then again when I put my stocker back on many miles later). I probably would have reused them again if my BadMab hadn't come with new gaskets.
