Intake Problem!! PLEASE HELP!!!!!
Old Feb 23, 2009 | 12:02 AM
cardelino18's Avatar
Exclamation Intake Problem!! PLEASE HELP!!!!!
hey guys!... i have an 08 cobalt ss/tc with the clear image tune... i tried putting a custom intake ( its just a small pipe to replace the air box and put the censor) and the car its not throwing any codes(check engine light) but it is not boosting at all.... any ideas why???
Old Feb 23, 2009 | 01:24 AM
Cobaltss/TC's Avatar
Well it is the intake of course, has nothing to do with the tune, the MAF sensor is EXTREMELY sensitive as to where it goes, also if you have any unmetered air going into the engine this will happen
Old Feb 23, 2009 | 01:30 AM
JsavageSS/TC's Avatar
Couldn't explain it better myself
Old Feb 23, 2009 | 04:37 AM
Maxim_X's Avatar
Backwards MAF perhaps??
Old Feb 23, 2009 | 07:13 AM
brickerenator's Avatar
all custom intakes belong in here
Old Feb 23, 2009 | 07:24 AM
blazinbaltss's Avatar
xxxx2
Old Feb 23, 2009 | 08:29 AM
SSturb's Avatar
try taking the negative off the battery to reset the ecu
Old Feb 23, 2009 | 08:39 AM
NorthernStar's Avatar
110 kPa
IE: If the pipe is wider than the MAF is calibrated to believe or there is a loose or non-airtight connection after the MAF.
Old Feb 23, 2009 | 08:58 AM
06CobaltssOrange's Avatar
just buy my BNIB 09ss/tc intake for 250 shipped
Old Feb 23, 2009 | 09:37 AM
i unpluged the battery and it still doing it... it works perfectly for about 3 minutes and now the check engine light is on... the maff sensor is in place and there is no air licking... any suggestions besides buying an intake?
Old Feb 23, 2009 | 09:39 AM
dude replace your stock intake
Old Feb 23, 2009 | 09:45 AM
D4u2s0t's Avatar
pics of this intake? it's fairly tricky to make a well designed, working intake. the maf has to be in the right area, at the right angle, in the right size piping, etc. this is why we don't all piece together our own kits.
Old Feb 23, 2009 | 09:49 AM
eiuprtycntrl's Avatar
i am having this problem with my intake as well. Clear Image is working on an intake that will fix this problem
Old Feb 23, 2009 | 11:16 AM
Terminator2's Avatar
Dude, you need to seal off the vent hose air leak that you have right now, that might fix your problem. I have a custom tune and I installed a Dejon intake after I had it tuned and I have no issues to speak of. Still pulls hard, boosts the same as programmed (holds 21 all the way to redline) and my gas mileage has not changed so I do not think it is the design of the intake per say but maybe an air leak or maybe it is loose at the turbo connection make sure you check the connection at the turbo.
Old Feb 23, 2009 | 11:33 AM
XxCOBALT_TURBOxX's Avatar
Hell yeah my 08 ss/ tc is doin the same thing I'm only boostin like 7 pounds!! But mine is the Dejon and I'm stock tuned
Old Feb 23, 2009 | 11:34 AM
did you have the valve cover vent hose connection on your intake?
Old Feb 23, 2009 | 11:35 AM
Damn this sucks to see all these problems with Dejon, i really like their stuff and i know they have quality parts hope they can fix the issue with a simple fix like mentioned above
Old Feb 23, 2009 | 11:36 AM
How did u seal urz? Cus my vent hose is very lose
Old Feb 23, 2009 | 11:37 AM
yeah it does suck.
thats why... you need a tune in order for the intake to work... my problem is that i replaced the airbox with a pipe and plug the sensor in but its not working... my boost is at 0 when i press the gas... when i disconect the battery and plug it back in it works for about 3 minutes and then the check engine light comes on... and it stops working...
^ that's what I need to know. How the hell do you seal it
Old Feb 23, 2009 | 11:38 AM
Yeah but it fits very lose
where is the vent hose?? which one is it?
Old Feb 23, 2009 | 11:44 AM
I used a 3/8 inch fuel line tool (you use to remove the fuel filters from fords) to remove the stock stainless hose for the car. A mechanic or auto store should have the tool. Then you need about 1.5 ft 3/8" ID heavy duty rubber hose and two hose clamps and you have fixed the problem. Or you can sometimes find a product in the help section of the autostore called an emissions hose someone else used that to fix theirs. It has a double berbed fitting that fits the stainless hose and a rubber hose that attaches to the other end of the barb and the intake. I know it is hard to understand, but I dont have pictures.
small nipple near the top of the intake with a clip hose that connect to your engine
