Interceptor Gauge Helppp
Old Jul 26, 2011 | 03:35 PM
TurboMatt's Avatar
Ok so does anyone if the intercepter gauge for the ss/tc needs to use the power wire or is the OBD cable the only on you need?
Old Jul 26, 2011 | 03:36 PM
07BoostedG5's Avatar
You have to use the power wire....all cobalts have constant power to the obII port so it will never turn off. remember to pull the jumper out.
Old Jul 26, 2011 | 03:40 PM
MS3 2 SSTC's Avatar
OBDII.. My dual interceptors are plugged in thru the OBDII. they turn on when you start the car and turn off after 1~2 minutes after you turn off the car..
Old Jul 26, 2011 | 03:41 PM
EXsoccer1921's Avatar
yeah the ones for the tc can be plugged right in to the obdII no need to use to power wire. different gauge than the lsjs
Old Jul 26, 2011 | 03:43 PM
ah my mistake, I swore the last guy going thru this was a lnf, my bad!
Old Jul 26, 2011 | 05:10 PM
TurboMatt's Avatar
aweome i was hoping it would be that easy thanks guys
Old Jul 27, 2011 | 01:00 AM
MS3 2 SSTC's Avatar
No problem man. That's what we're here for...to help each other out
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
