Intercooler Damage - Pics - What are my options??
Old Jul 1, 2014 | 01:26 PM
Metlhed54's Avatar
Thank you in advance, I went through a puddle last night and ended up damaging my intercooler. The metal broke on the passenger side where there is a screw holding this "drip tray" looking part that runs along the bottom of the intercooler. There are no cracks that I can see in the side tanks, it seems that the only break is on the piece of metal where it attaches to the main core of the intercooler. I have thrown no codes, seem to still hold boost although I haven't pushed it to find out.
Old Jul 1, 2014 | 01:31 PM
Your pic didn't load correctly.
Options are use the search function, intercooler replacement has been covered multiple times.
Old Jul 1, 2014 | 01:44 PM
tomj77's Avatar
Is that the stock plastic garbage? Why isn't it replaces yet? Zzp.
Old Jul 1, 2014 | 02:08 PM
Omiotek's Avatar
No reason to replace the stock intercooler unless it's broken. It works awesome and is perfectly paired on the stock turbo.
Shanedude's Avatar
It wasn't the plastic that broke...Do you even read the thread before posting lol.
Old Jul 1, 2014 | 02:21 PM
thatzthastuff's Avatar
From what I remember reading I'm pretty sure you're fine if that's the extent of the damage. If you're worried I have a stocker or get a ZZP
Old Jul 1, 2014 | 03:02 PM
user 72239's Avatar
Time to buy a minivan
Old Jul 1, 2014 | 03:27 PM
CudaJoe's Avatar
looks like your okay. get some kind of epoxy on that tear in the metal to prevent it from tearing more.
Old Jul 1, 2014 | 04:10 PM
Metlhed54's Avatar
I just went and bought some JB weld, it looks like I should be able to just epoxy it. I was worried I broke the plastic tank too, but it doesn't seem to have cracked it. Hopefully, this will fix it. Thank you for the help!
Old Jul 1, 2014 | 04:27 PM
Damn puddles.
Old Jul 1, 2014 | 04:31 PM
Shanedude's Avatar
Same puddle?
Old Jul 1, 2014 | 07:07 PM
tomj77's Avatar
I never said the plastic broke. just that its garbage. rather change it now then have to deal with it breaking when ur out in the middle of nowhere.
Old Jul 1, 2014 | 07:14 PM
Shanedude's Avatar
Could you not just duct tape it(no foreign material entering system) and drive home in limp mode? It wouldn't make the car un-driveable would it?
Old Jul 2, 2014 | 02:00 AM
GTOworshiper9's Avatar
You need a new one. It's punctured/torn. It might just be the "drip tray" but how do you think the oil - mist from the pcv gets in there?
Old Jul 2, 2014 | 02:02 AM
wol-shiver's Avatar
Omiotek is crazy. Get zzps broken or not. The condensor is for water or oil. U can take it off and plug it underneath each mounting point.
Old Jul 3, 2014 | 06:34 AM
umrdyldo's Avatar
You have 2 options. Take the condenser off the bottom. Believe it's a screw on both ends. You will then need to plug the hole left on each end.
Or option 2. Get an aftermarket intercooler.
Old Jul 10, 2014 | 12:02 PM
GreenySC2's Avatar
replace it, hands down...
Old Jul 10, 2014 | 03:09 PM
Shanedude's Avatar
Plug it if your on a budget. It is not a priority to replace a working unit unless you have cash sitting wanting to be spent/mod bug.
Old Jul 10, 2014 | 05:02 PM
Grimor's Avatar
Originally Posted by Shanedude
I have nothing to add to the topic, but that puddle was in the dollar store parking lot in my town.
Old Jul 12, 2014 | 01:29 PM
Sl0wbaltSS's Avatar
Dealer just took it off and put it in my trunk. Mine was loose. [if you know what I mean]
Old Jul 12, 2014 | 02:08 PM
SSlobalt's Avatar
Then you have a boost leak from the little brass holes.
Old Jul 15, 2014 | 03:59 PM
Hemphog's Avatar
I fall under the Sl0wbalt category...two years with the piece removed. Sub'd good/bad...
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
