Just programmed my car with Hahn's PPC
Old Aug 18, 2008 | 06:41 PM
glhs379's Avatar
Got it in the mail today and programmed my car just now. Could not be any easier. Just plug it in, hit enter, and in about 30 secs its programmed.
I took it for a ride and it goes right to about 21 to 22 psi and stays right there in each and every gear!
Even pulled the steering wheel out of my hand when the boost hit in third gear, was not expecting that.
I have no other mods but a k&n drop in.
I did get to play with a Csrt4 while I was out "testing" the car just now. The kid was on a test drive from the dodge dealer local.
I will post that encounter in the war stories area.
Overall I am very pleased with the tuner, did everything Hahn and BSR said it would, easy to install, noticable inprovement, and No boost spikes.
Old Aug 18, 2008 | 06:57 PM
BostonBoy's Avatar
This is nice to hear. Keep us posted on the long term.
Old Aug 18, 2008 | 07:15 PM
jerrodmann's Avatar
x2...........
Old Aug 18, 2008 | 07:19 PM
BlueSS-supercharged's Avatar
louder?
Old Aug 18, 2008 | 07:22 PM
glhs379's Avatar
Just an FYI
It says in the owners man with the ppc that due to higher boost levels, to tighten the intercooler piping.
I just got done doing that thinking they would already be pretty tight, boy was I wrong, all of them took quite a few turns.
The one exiting the turbo at the top and the two at the ends of the intercooler core are 11 MM wrentch jobbers and the one right at the TB(you will need to jack the car up and get at that one, is 8mm, which you can get with a socket and rachet.
The 11 mm are screw types, but be careful with the Tb one, it is just a reg hose clamp, and DO NOT overtighten it, as you can very easily strip those kind!
Just a heads up
Louder, not really
Just alot more boost!
Very responsive.
Old Aug 18, 2008 | 08:06 PM
Psykostevo's Avatar
It took me 28 seconds to flash my 2 test cars each.
The car is not really any louder, and either is the boost bypass. It's silly how stock it sounds, and the power is so smooth it doesn't jerk you around when you stomp the gas. Just a little torque steer, but you can muscle through it.
Old Aug 18, 2008 | 08:10 PM
glhs379's Avatar
The power is very smooth and linear.
very deceiving until you look at the speedo
Old Aug 18, 2008 | 08:17 PM
Psykostevo's Avatar
That's what I thought. It felt like there was no change in boost, then I looked at the boost gauge and my eyes shot open. I'm seeing 22-23psi all throughout the powerband.
So what other cool things can you do with the PPC? Does it show you the wideband readings or anything like that, or let you make other changes like some of the other scanners do?
Old Aug 19, 2008 | 12:41 PM
rocco11189's Avatar
go dyno it see what its putting down
Old Aug 19, 2008 | 12:48 PM
jwhitten's Avatar
Do you think its worth the price? Or should I go with hp tuners?
Old Aug 19, 2008 | 02:00 PM
Psykostevo's Avatar
Saturday....saturday.
Old Aug 19, 2008 | 04:09 PM
MARIN007's Avatar
I'm still a bit confused on why the car still traps 104's with the tune. Anyone shed some light on this? Why is the Hahn tune giving this extra power/torque but still trapping the 1/4mile with the same trap as my stock SS/TC? (Note: This is not a bashing of the product, I'm just curious)
Old Aug 19, 2008 | 04:33 PM
Psykostevo's Avatar
Need Driver Mod!
Rissa's Avatar
Originally Posted by Psykostevo
Need Driver Mod!
I have dibs on you.
Old Aug 19, 2008 | 04:44 PM
OntarioKev's Avatar
If I remember Hahn's passes were getting something like 2.090 60 foot times.
You were around 2.2 for your 104 pass Marin.
I believe the quicker 60 foot time would yield a better ET and a slower MPH then a higher 60 ft time.
So if the Hahn kit ran a pass with a 2.2 60ft time his MPH would likely be higher.
Kevin
Old Aug 19, 2008 | 04:50 PM
Psykostevo's Avatar
Originally Posted by Rissa
I have dibs on you.
Mmm :-P
Kevin
Also, you should be shifting at redline, and using the NO-lift shift. Any miss, and your mph and time will suffer.
Last edited by Psykostevo; Aug 19, 2008 at 04:50 PM. Reason: Automerged Doublepost
Old Aug 19, 2008 | 04:52 PM
Rissa's Avatar
Yup you get here and I'm not letting you go ahahaha.
Old Aug 19, 2008 | 04:55 PM
Psykostevo's Avatar
I'm sitting with my business partner that owns the international Solstice/Sky club and he's posting up tuning for the LNF on his boards, trying to get a SoCal group together for tuning because he has 60+ members there.
Old Aug 19, 2008 | 05:01 PM
Rissa's Avatar
Yaaayyy!!!
Old Aug 19, 2008 | 05:52 PM
glhs379's Avatar
You do have to compare track conditions when comparing et and mph
you can't just compare the times
elevation, humidity, temps, etc
so one person 104 mph may be actually much higher under a diff set of conditions.
like dynos, tracks all vary alot.
From hahn's post
Elevation: 660 feet
Conditions: 77-84 degrees, high humidity, 2500 feet adjusted altitude
2500 ft adjusted altitude is very high, also high humidity and temps that day.
Take that same run and go to englishtown or atco NJ(sea level) track, and that pass maybe 108mph+ in cooler fall temps.
As far as If I think it is worth the money?
depends on what you plan to do.
I have mine as a DD, so I will not go too crazy, maybe a cai and hahn's intercooler when it comes out, nothing more
so the PPC is good for me
if you plan a turbo swap, etc, you will need it tuned by somebody on a dyno at that point and a canned tune is not what you need to by, spend the 1k on dyno time and tuning at that point.
heck, people spend almost a 1k on a cai and a catback in the honda world and never get a 1/5 of what the PPC gives you, based on the initial dyno numbers
just my 2 cents
Wazaroonie's Avatar
very nice.
Old Aug 19, 2008 | 10:18 PM
fuente27hpv's Avatar
i would love to see a dyno, i was thinking about getting this with alot of bolt ons and maybe a 50 shot, hopefully i can see 400 HP, it wont happen for a while though if not, bigger turbo i guess. I know its going to be a while before we see some major mods coming out, I guess I will just wait and see. Some dynos would be nice
Old Aug 19, 2008 | 11:40 PM
ssturbd08's Avatar
i wanna get one for my car, how does it perform against other cars?? any races or messin around??
Old Aug 20, 2008 | 02:54 AM
PimpLay2's Avatar
i think i will go with hptuners but keep us up to date oh the ppc
Old Aug 20, 2008 | 12:12 PM
Psykostevo's Avatar
I should have 2 cars on the dyno this Saturday at 2pm.
