Just programmed my car with Hahn's PPC
i would love to see a dyno, i was thinking about getting this with alot of bolt ons and maybe a 50 shot, hopefully i can see 400 HP, it wont happen for a while though if not, bigger turbo i guess. I know its going to be a while before we see some major mods coming out, I guess I will just wait and see. Some dynos would be nice
I ordered mine... but they are supposed to send an email to me first I believe.
I haven't gotten the email yet. I did call an hour before closing on Friday though...
How long did it take you all to get an email?
I'm just excited to get this going. Other than a drop in K&N this is all that I plan to do. Although once I get bit by that bug.. you know. I'll run into a car that's just a lil bit faster and have to do something else. Way it always goes....
I got my email from hahn the next day, and it was a form to fill out, as they need your VIN to program the PPC to your car before they ship it out to you.
BTW, I have had it on the car for over a week, no issues at all and no drop in fuel econ.
I should say that there is NO WAY to make the fuel economy worse on these cars when not under boost. The car commands it's own AFR, so you're golden. Obviously if you drive under boost often your MPG will go down, but nobody should be doing that all the time.
hmmm, so how much does it cost per car? how is psyko doing this for $300 a piece if its only 1 car per tuner
yes because you know nothing about tuning
Last edited by hatrickstu; Aug 23, 2008 at 05:03 PM. Reason: Automerged Doublepost
Boost is not that high in first gear for obvious reasons. I just got my PPC, The tq is monsterous in second and third, even 4th gear from a low speed\low rpm, the car just responds RIGHT NOW! Hahn is also in a much warmer area Jolkiet, Ill with higher humidity than most of ontario other than the southern parts, and still much cooler at night there in CAN to. The 3 tack elevatios are all within 300 feet of one another in Ontario, and close to the one in Ill.
One thing I did notice, while doing a top speed test run on a closed runway at the AFB is that the car seems to run out of steam at about 135, and from then on it goes real, real slow. A friend with GM confirmed that the car is governed at 142 or so. That explains why it seemed to not go much faster, or maybe the PPC lowered the top end by improving on the bottom? Either way the car hits a brick wall, slowly at about 140.
The auto mags say drag limited to 160 and with the big high wing it's limited by drag to 147 . I have the small spoiler\wing . I would not take the auto mags word for much these days.
My car before PPC in 100* air, track is 1240' and a DA of 4479' with unusually low pressure of: 29.66 ran a 14.10 at 101 mph >>> 100% stock. After the PPC in almost identiacl weather, 13.49 at 106.88 mph. Nice! Now I need traction as it does not exsist in first gear even at 75% throttle, and spinning wheels in the 1-2 transition. A rep for Mickey Thompson was at the track and came over to me and gave me his card. He stop-watched my wheel spin: I'm wasting nearly 8 tenths of a second (nearly one full second) spinning the tires. I'm calling him monday.
This PPC has two stages to it as bolt-ons get made and or the tubo is upgraded. Free software updates at the BSR web site too. BSR is the worlds formost leader in tuning of turbo charged cars. I've had their products on some of my cars from 15 years ago.
Last edited by SportredSS; Aug 24, 2008 at 03:50 AM. Reason: Automerged Doublepost
My Acura RSX with roughly 35-40 less hp (after mods) would do 148ish. So maybe just gearing where the hp max is. Certainly my new SS/TC would kill it in the 1/4 though.
Not a big deal I guess as I'm sure most of us don't have a need to be going those speeds anyway.
You can very easily flash it back to stock before you take it in. If they were just absolutely dead set on finding out if it was reflashed before I'm sure they have ways. But I'm sure they don't just go around checking that stuff either even if they do have that capability.
