K&N air filter?
Old Sep 20, 2009 | 12:31 AM
rukkee's Avatar
Originally Posted by jamoe73
Question regarding Air Filter change. I've got a 2007 SS/SC (Sport Tint Red by the way). I went ahead and bought a K&N Air filter to replace the OEM filter. My question is: How do you swap out the Air Filter? Do you have to remove the Head light or fender wall to get at the Air Box? I don't have the factory repair manual. Help out please. Thanks.
Jim
On the SS/SC you have to pull the splash guard infront of the drivers side wheel . The easiest way is to pull the front DS wheel off and then unscrew the plastic bottom of the splash guard . Pull all the screws underneath and three from the bottom up.. in the wheel well . Then pull the splash down and hold it or fold it around to where the ground holds it it's self. You will then see the Air box. There are 4 screws that hold the bottom on . Once you do it a couple of times you can get it down to a 10min job.
The headlight removal trick only works with a aftermarket intake , at least i could never see a way to get the filter to drop out the bottom of the air box with the splash guard still hooked up.
no_ss
Oct 18, 2015 11:58 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
