K&N Drop-In MAF question
Old Aug 8, 2009 | 03:54 PM
EcotecAddict's Avatar
For those with the K&N Drop-In filter, has anyone experienced any problems with the MAF sensor? Just want to know if people are experiencing skewed MAF readings like I've read occurring with some of the aftermarket intakes.
Old Aug 8, 2009 | 04:01 PM
rukkee's Avatar
I've seen as much as -7 LTFT with a K&N drop in and the superchips tune, usually it sits around -5 . I can't say if it's the tune or the filter thou. Maybe ill throw my stock filter back in and see what it reads.
Old Aug 8, 2009 | 04:12 PM
Bandit1's Avatar
Hmm.I am tuned and have k&n filter but not tuned for the filter.1st gear is whacked,but everything else feels good.
Old Aug 8, 2009 | 04:46 PM
Iam Broke's Avatar
Stock air box snorkeless mod, had -1.6 LTFT's with the K&N drop in, not enough to really worry about it being off.
Old Aug 8, 2009 | 04:54 PM
Terminator2's Avatar
It should not be the tune causing the LTFTs to be that negative. Mine is -1 to -2 with the stock filter but removing the filter it went to -7 to -8. I attribute that to the airflow turbulance because there is no filter element to straighten the airflow. CP leak can cause negative fuel trims too.
Old Aug 8, 2009 | 07:26 PM
Zander916's Avatar
A LITTLE off topic... I just checked my K&N drop in. It's got nearly 25K miles on the filter. I was happy to see the whole filter was equally dirty. In the past even with cone filters I seemed to have a problem where one part of the filter took the majority of the airflow. Therefore it got the most dirty, and much faster. This is nice and even.
Old Aug 8, 2009 | 07:53 PM
BLACK2007LS's Avatar
...i had no problem
Old Aug 8, 2009 | 08:00 PM
turbaltss's Avatar
no problems with mine
Old Aug 9, 2009 | 02:47 AM
rukkee's Avatar
Thanks for the info . I'll check my charge pipes again , I tightened them less than a month ago for the 2nd time . I'm gunna put the stock filter back in and see where the trims settle .
Old Aug 9, 2009 | 12:32 PM
Hill1513's Avatar
Keep us updated rukkee.
Old Aug 9, 2009 | 12:57 PM
rukkee's Avatar
Mine doesn't have the miles on it that yours does but ..... I can see one area that is getting dirty . It's not even at all , I'll get a picture of it today
Will do .
Old Aug 9, 2009 | 09:59 PM
umrdyldo's Avatar
I took the snorkel out and my fuel trims are still at -5% with my K&N and my IAT1 didn't raise at all.
It might be in my head but the turbo is more audible.
Old Aug 10, 2009 | 12:40 AM
Gettinausernamesucks's Avatar
I've run almost every combination you can imagine. K&N-Snorkle (runs fine no issues)Short CAI/W MAF in stock position(Works Fine, Tip in throttle whistle is annoying as ****) Long CAI/W MAF in stock location and filter down in the pocket.(Ran Like Dog ****, LT fuel trims all outa whack) Long CAI with MAF moved 6 inches further downstream (the best as far as a CAI setup, however high risk of sucking water because it shoots right past the fog lamp at the filter) And currently Stock Airbox-Snorkle with full 3 inch tube froom the turbo to the airbox with a KN drop in. (This is the best so far. Stable fuel trims, No whistle, and I can tell it flows as hard as a full cai or a shorty)
I am using a modular system so I can move pieces all around.
Dropping the snorkle is job numero uno if your keeping the stock airbox. By the way -5 plus 5 is no big deal and to be expected in normal operation. When you start seeing -15 to-17 or +15 to +17 type LTFT's something ain't happy.
I am a GM engineer and my opinions are my own.
Old Aug 10, 2009 | 11:55 AM
umrdyldo's Avatar
how muvh restriction is there in the snorkel?
seems like a lot
Old Aug 12, 2009 | 11:07 AM
rukkee's Avatar
Well after reseting my fuel trims and putting 200 miles on the stock filter......my long term is at 0. The K&N was sitting right around-5.5 but i've seen -7 LTFT's in the past . So what do you guy's think stay with the stocker or put the K&N back in ? Thanks
One thing i did when i put the stock filter back in was trim the snorkel where it comes into the air box. The snorkel had a big lip that went inward ....hard to explain but on the inside of the opening that comes into the air box there was a lip of curled in plastic ....which was making the opening smaller . So i just trimmed it out and made the inlet smooth. This prolly wont make any sense but thats it lol.
Oh and the foam that is supposed to seal the snorkel to the air box was sticking out where the ends of the foam meet , i could see day light looking down threw the air box where the snorkel comes in . So I'm gunna test the K&N again and see where the trim's end up.
Old Aug 12, 2009 | 11:09 AM
Stay with the stock filter.
Old Aug 12, 2009 | 05:13 PM
Routs's Avatar
Interesting. Why?
Old Aug 12, 2009 | 07:13 PM
Hill1513's Avatar
Originally Posted by Routs
Interesting. Why?
x2 I've heard this argument before. But I'm game for a repeat lesson.
Particularly from a guy putting down 345 at the wheels.
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
