Is this a lasher or im stupid
Old Oct 7, 2011 | 10:08 PM
DillySS's Avatar
I am so annoyed. This sound is during warm until 189 or if the engine is warm and I turn the car on it lasts about 1 minute and goes away.
Untitled - YouTube
Old Oct 8, 2011 | 08:55 AM
Iam Broke's Avatar
Could be a lash adjuster, a bad cam follower or just a noisy HP fuel pump. Odd that the noise changes so much when it goes into closed loop though. Awfully metallic sounding in the vid.
Could be a lash adjuster that quiets down with heat and oil or just injector noise.
Can you get a stethoscope to listen to the injectors under the intake manifold & HPFP?
Old Oct 8, 2011 | 09:28 AM
raver0789's Avatar
My car does the same thing. Its been doing it forever since it was almost new. Once the car is warm it goes away. I still beat on it all the time, no issues. Your car is probably okay.
Old Oct 8, 2011 | 09:32 AM
raver0789's Avatar
What temp is it right now where you live? Is this on cold start ups only? How many miles on the car? I have always assumed it is my car just warming up. Precisely why I don't give it any juice until it gets up to op temp.
Old Oct 8, 2011 | 11:08 AM
SSean's Avatar
direct injection
That noise is not the valves. It is the cold start in the direct injection. It is spraying more fuel to get the engine warmed up.
Old Oct 8, 2011 | 12:04 PM
SSPainter's Avatar
seems normal to me.
Old Oct 8, 2011 | 12:36 PM
Iam Broke's Avatar
I think you are right. Hard to tell in the vid for sure. I had the cat warmup disabled for so long I forgot all the racket it made, that would explain why it quiets down when it goes closed loop.
That is why I suggested he listen to the injectors in my post above.
Old Oct 8, 2011 | 05:50 PM
xodus's Avatar
Its normal mines done it since new.
Old Oct 11, 2011 | 08:51 PM
DillySS's Avatar
I have issues with a air/fuel. I am just checking all the bases.
Old Oct 11, 2011 | 09:08 PM
Mike_peperni's Avatar
Mine does the same as well.
Old Oct 11, 2011 | 09:49 PM
cobaltssoverbooster's Avatar
2008 and its been doing that ever since....its the di/hpfp in the warmup cycle
Old Oct 11, 2011 | 11:34 PM
NME's Avatar
NME
Pull the valve cover. Look and see if you can find anything only takes a few minutes.
Tupp
Sep 29, 2015 11:07 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
