LNF Adjustable Launch Control by Trifecta
Old Mar 11, 2011 | 07:55 PM
  #151
MS3 2 SSTC's Avatar
Originally Posted by vincetrifecta
the update for ez flash to adjust launch control is available on our website now. Just redownload ez flash in accordance with the original instructions you received for downloading ez flash, and the option is now available. The instructions for ez flash have been updated also describing how to use this feature. Thank you to everybody who helped test it and provided feedback.
you are a god!!!
Old Mar 11, 2011 | 10:35 PM
  #152
08inBama's Avatar
ok so on the new EZ flash, do I just go to Program, Adjust Tune Setting, 2.0 LNG, set it to my desired setting and then hit Force Full flash? I don't want to overwrite my existing tune.. so how do I modify it?
Old Mar 11, 2011 | 11:03 PM
  #153
ssblackstealth's Avatar
corn gas ftw....
no force flash required, here you go...
after selecting your %age, then you select your current tune file
but i dont think this software is out yet for everyone, should still be testing only...
Old Mar 11, 2011 | 11:12 PM
  #154
08inBama's Avatar
so select 60%(for example), then accept that setting, then click on the engine and load my current tune?
Old Mar 11, 2011 | 11:14 PM
  #155
ctn2mb's Avatar
It's out for everyone but you change the setting like he did then load the last file he gave you
Old Mar 11, 2011 | 11:19 PM
  #156
08inBama's Avatar
ok... I guess i'll play around with it tomorrow
Old Mar 12, 2011 | 12:41 AM
  #157
bamaboy22's Avatar
Text me or call if u can't figure it out
Old Mar 12, 2011 | 02:39 PM
  #158
MS3 2 SSTC's Avatar
This is what mine sounds like. set to 60%
YouTube - Cobalt SS w/ Trifecta Adjustable Launch Control
Old Mar 12, 2011 | 03:05 PM
  #159
08inBama's Avatar
Yea I figured it out. Lovin' some 60%
Old Mar 12, 2011 | 03:26 PM
  #160
2010SS's Avatar
So I have the hp/tf combo tune... I also have the ez flash so if I try to adjust this will it overwrite my hp portion? Can't have that happening...
Old Mar 12, 2011 | 03:28 PM
  #161
MS3 2 SSTC's Avatar
I would contact Vince for that matter.
Old Mar 12, 2011 | 03:36 PM
  #162
VinceTrifecta's Avatar
Yes, it will. Here's how it works for hp/tf users:
1. Use EZ Flash to write the tf layer to the ECM, with a selection of something other than 100%
2. Use HP to write your HP tune over the top
3. Use HP to adjust the launch control RPM by tweaking the Rev Limiter Short Incr table for Park/Neutral
If you want it adjusted and you don't have HP, you'll have to contact the person who did your tune to get it adjusted.
Old Mar 12, 2011 | 03:40 PM
  #163
2010SS's Avatar
Well that was quick vince haha...But yea no hp so o well
Old Mar 12, 2011 | 03:42 PM
  #164
At some point, I'd like to make it user-adjustable via the accelerator pedal like the GMS3 LSJ tune does. That would be sweet.
Old Mar 12, 2011 | 04:03 PM
  #165
2010SS's Avatar
Yea that would be awesome
Old Mar 12, 2011 | 06:01 PM
  #166
YelloEye's Avatar
That would be awesome.
Old Mar 13, 2011 | 05:34 PM
  #167
08inBama's Avatar
I bumped it up to 65% today and it launches much better...
60%(3000rpm) was great in the 75 degree weather, but when the temps went down to the high 50s last night, it was bogging... I set it at 65%(3200) today and I like it a lot more...
my friend and I broke out the old G-Tech Pro today which I know is not accurate however it is pretty good at comparing your own vehicle and if you've made improvements or not... before my best 0-60 was 5.1, though I averaged 5.3 or so... today, 1st pull I hit 4.7
so its definitely faster out the hole and i've always been a manual launch person... but I honestly think this is faster than I have ever launched it manually and i've turned a 2.0 second 60 ft. on street tires launching manually at the track
Old Mar 13, 2011 | 05:42 PM
  #168
SuperchargedSS's Avatar
Fukin sick ****.
Old Mar 14, 2011 | 11:52 AM
  #169
soundjunky's Avatar
wow - you posted EXACTLY what I was thinking...
So do you know why the tach is so far off when this feature is used?
>>Is this something you might be able to fix??
This is very cool btw.
Old Mar 14, 2011 | 12:50 PM
  #170
To make this work we basically have to lie about the engine speed to the rest of the modules in the vehicle. It's the only way to adjust the factory launch control by reflashing the ECM. The instrument panel listens to the same message we have to modify so it displays inaccurate tachometer reading.
We designed it so we only lie when competition mode is selected and the vehicle isn't moving, so it's only when you're launching that the RPM displayed is incorrect. Once you start moving, it goes back to normal.
If you have a dashawk or interceptor, or some other OBD2 datalogger, it will display the proper RPM always.
Old Mar 14, 2011 | 01:15 PM
  #171
soundjunky's Avatar
interesting.. if you posted this before I missed it ~ thanks for the explanation!
Considering what you know about the LSJ-GMS3, how feasible do you think it might be to set the launch control via the pedal?
Old Mar 14, 2011 | 02:02 PM
  #172
It's definitely possible, and it's definitely on our list of things to do.
Old Mar 14, 2011 | 07:29 PM
  #173
08inBama's Avatar
YouTube - 2008 Cobalt SS New Launch Control video.mpg
I think its time to turn my boost up in 1st, lol
Old Mar 14, 2011 | 10:58 PM
  #174
corn gas ftw....
told ya 65% was magic...
Old Mar 18, 2011 | 05:57 PM
  #175
superbrowndude's Avatar
I want !
