LNF Adjustable Launch Control by Trifecta
This is awesome.
Recently my tune install business has picked up, installed on a Tahoe last night and have a couple of silverado's asking a bunch of questions. Also have 2 lsj's waiting on parts to get tuned as well... but THIS update will drum up some more LNF business for me as well as improve my own ride. I'm happy!
Beta tested it this morning. Looks like it works great... I also made a video for you guys. I need to raise mine up just a little but you get the idea.
YouTube - Bad news racing tests trifecta launch control
need sticky tires when running it though. after releasing the clutch it just blows the tires free!
I have it on my car but I have a couple issues with it. Im going to let Vince know, Im sure it's dumb crap. But when I switch to LC, the RPM on the dash drops to 500rpm but the sound of the engine doesn't change. When I set it to 2500, its more like 1250. I now have it at 4K and the actual LC is around 2500.
Yeah I'm going to hook up my LM-2 to get an accurate reading of what % change will = a certain RPM on my car. I'm not sure what mine is at when in LC because I just did that video really quick to make sure it worked, but I set it to what should have been 2500 and it bogged really bad.
If you have a dashawk or interceptor (or you're datalogging via OBD2) the RPM will be correct (actual).
And it was the Normal Table to adjust it, not the incr table.
I took a vid for you Vince of the RPM dropping when I switch to LC mode. Ill send it to you in a lil bit, just getting crap together this morning lol
Lol
Yes, basically. Adjusting it requires an ECM reflash (with EZ Flash if you're running our tune, or HPT if you are using our layer), but you could bring your laptop with you, make an adjustment, test it, and try a different setting if it didn't work.
Do I need my tune updated or just my EZ Flash dealer software or both
