LNF AFR Error
Old Oct 18, 2016 | 01:06 PM
sev's Avatar
sev
LNF AFR Error
Hi all,
I am trying to setup an AFR ERROR parameter on HPtuners for an LNF.
Currently I have it set up as [6005.238] - [6160.238]
Both WB EQ ratio and Equivalence Ratio commanded are enabled on the channels.
For the graph I have to
Column Axis = Absolute Load
Row Axis = Engine Speed Sensor
(The axis values match the Maf correction table)
Decimal = 3
Then setup another graph so it mimics it exactly but for STFT+LTFT Math parameter
Is this the correct way to set it up?
If so I take it that after a log these are added over to the Maf correction table?
I am trying to troubleshoot an error where the STFT will just default to 0 and the Wideband reading goes out of control. The CMD lambda matches the PE table but the fuel goes way lean or way rich.
It happens randomly and it happens with or without the maf. Replaced the maf as well.
Old Oct 18, 2016 | 04:32 PM
umrdyldo's Avatar
How many miles are on the car? Might be that your wideband sensor is going bad. Tends to happen after a few years.
The wires to my sensors rubbed through cause the Fuel trims to stop working.
ThoR294
Wheels and Tires
Mar 7, 2017 02:52 PM
Slobalt_joe
Nov 16, 2016 10:04 AM
street253
Oct 5, 2016 08:37 PM
Batmobil
Oct 3, 2016 11:32 PM
08 burgundy Balt
Sep 26, 2016 01:59 PM
