LNF engine standalone running, now a question
Old Nov 27, 2013 | 10:10 PM
maccos's Avatar
Is it normal that in neutral, no load, I should not be able to hear the whistle of the turbo. I ask because I dont hear anything. I dont have axles yet, so I cant put a load on the engine. I guess I was expecting to hear something.
This is for my Ariel Atom replica build:
ModernKitCar.com
LocostUSA.com • View topic - Another At-om Replica Build
Old Nov 27, 2013 | 10:14 PM
Under no load means no boost right? No boost = no whistle.
Old Nov 27, 2013 | 10:22 PM
noorj's Avatar
sometimes with other motors you'll be able to hear the turbo without load, but it is normal that you cannot.
just read your build thread, great work man! got a lot of respect for a guy who truly builds his own car
Old Nov 27, 2013 | 10:53 PM
maccos's Avatar
You guys are quick. So I am referring to these two videos that are also running lnf standalone, which appear that each of the videos, there is not much load on the engine, although I can hear the turbo. The CBM video doesnt even have a tranny on his engine.
Old Nov 27, 2013 | 10:57 PM
raver0789's Avatar
Depends on your exhaust system. That guy basically has an open downpipe which is short so you can hear a bit. Honestly the turbo is so small you won't be able to hear much with a full exhaust system that u have. BTW that will be an absolute rocket if you arent familiar with what these motors put out with just a tune alone.
Old Nov 27, 2013 | 11:09 PM
noorj's Avatar
your cat is probably quieting the turbo a lot also
Old Nov 27, 2013 | 11:11 PM
Omiotek's Avatar
Whistle all comes to play with your exhaust. You can have absolutely no load or anything and still here it... no cat no muffler or anything and it will whistle away. Add a cat resonator or muffler and it goes away. You might here it slightly with certain mufflers or resonators only...but that's if your cat less.
Old Nov 27, 2013 | 11:38 PM
maccos's Avatar
I gotcha, seems that I have a stealth setup.
Here is the video of my setup
http://www.locostusa.com/forums/down...3600&mode=view
Old Nov 28, 2013 | 10:41 AM
Lnf kit ariel atom??? Omg want lol
Old Nov 28, 2013 | 07:35 PM
tomj77's Avatar
if ur exhaust is pretty open, no cat, res, or muffler, then yes u should be able to here tubo whistle. even when ur not in boost the turbine and compresser are still spinning, just not fast enough to build boost. so u will still get that awesome turbo whistle. sounds kinda like when u here a semi truck turbo spool.
Old Nov 28, 2013 | 07:38 PM
tomj77's Avatar
LNF Powered Airboat Engine Running 001 - YouTube
CBM lnf ecotec 2.0 turbo CBM Motorsports runstand - YouTube
totally normal.
Old Nov 28, 2013 | 07:42 PM
tomj77's Avatar
u do know the turbo still spins under no load right? as long as the engine is running its spinning, and making the whistle sound. u just cant hear it on most cars cause the exhaust silences it. u should have heard my talon before I put the downpipe and exhaust on,was awesome, all u could hear is turbo. and driving slowly, like 30mph, when u let go of the accelerator it was even louder than when u boosted it. once there exhaust was all bolted on, no more sound. was sad
Old Nov 28, 2013 | 08:10 PM
No way dude, the turbo only spins when you hit the boosts. -_-
Old Nov 28, 2013 | 11:12 PM
tomj77's Avatar
lol
Old Nov 29, 2013 | 08:03 AM
raver0789's Avatar
Love the responses on here, everyone has to repeat what I said at the top ten thousand times
Old Nov 29, 2013 | 02:09 PM
Fastgti69's Avatar
Badass, I've seen a few with the stock LSJ engines out here in socal. An LNF though... wow, with a tune in that thing. You'll be eating anything alive, the torque will scare you.
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
hhrfreek
Jun 4, 2016 11:25 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
