LNF Forged Internal Build!!!
Old Sep 28, 2010 | 01:31 AM
Do_WorkSS's Avatar
Originally Posted by Maupin SS/SC
loving the last pic....you dont fit in. AT ALL
agreed. hell compared to those cars his looks like a ****** geo metro. no disrespect to the OP.
Old Sep 28, 2010 | 01:35 AM
elecblue06's Avatar
you're a homo.. good luck on your build bish
Old Sep 28, 2010 | 04:19 AM
RyRidesMotox's Avatar
Sub'd
Sounds like a good build. Sleeving makes for easier rebuilds in the future. Well you don't have to shave the original block anymore anyways. But that looks like a bitchin setup you got there... I thnk I speak for everyone here when I say we want timeslips when you hit the track. Good luck dude.
Old Sep 28, 2010 | 04:31 AM
badbaltguy's Avatar
good luck with all that
Old Sep 28, 2010 | 04:32 AM
badbaltguy's Avatar
any plans for valvesprings & valves?
Old Sep 28, 2010 | 04:51 AM
AndrewSS/TC's Avatar
Sub'd.
Can't wait to see numbers.
Old Sep 28, 2010 | 12:44 PM
elecblue06's Avatar
Originally Posted by RyRidesMotox
Sub'd
gen 2 blocks generally dont need to be sleeved.. so unless he's going for like 600-700 whp it seems kind of like a waste of money
Old Sep 28, 2010 | 12:51 PM
09CobaltSS1's Avatar
yes gen 2 blocks are rated for a little under 1000hp, however the sleeves are rated for only 400bhp. Obviously they've been pushed quite a bit further without issues, but hey you can never overbuild a motor.. especially a bottom end.
Old Sep 28, 2010 | 01:00 PM
northvibe's Avatar
Originally Posted by redcomet303
Please don't neglect your Head!!!!!!!!!
It seems you have the money now start getting some springs and get that head ported.
it helped on the ms3 mzr, I think zzp said it helped some too but maybe not at the cost of porting it. But what do I know, I'm low on coffee and tired as hell with no memory what so ever.
Old Sep 28, 2010 | 01:09 PM
elecblue06's Avatar
i thought the sleeves were rated to 600 hp? my fault
i've know they've been pushed there though lol
Old Sep 28, 2010 | 01:26 PM
  #36
Ferretts's Avatar
Think about what you just said... how can a block be good up to 1000 hp yet the sleeves are only good for 400 bhp?
and im confident with the block as far as i can push this setup. Eventually when i do a ZZP 256 setup i still do not think i can hurt the block, Im not too concerned.
Old Sep 28, 2010 | 01:32 PM
  #37
I did think about what I said.. hense me saying it... so relax. A block rating is completely different than a sleeve rating. The gen 2 block is VERY strong, however the 2 weak links in the bottom end components are the sleeves and the pistons. Unless these numbers given directly from GM's build book are somehow wrong. I very much doubt that though...
Old Sep 28, 2010 | 01:46 PM
  #38
elecblue06's Avatar
you'd be surprised how much misinformation is in the build books actually
Old Sep 28, 2010 | 01:49 PM
  #39
ehhh if anything I would call it more "conservative" than misinformation really. I mean like you said, the sleeves have been proven to hold quite a bit more than 400bhp, and the pistons.. well those have been sort of hit or miss depending on the setup and tune. I think that GM just rated the componants for a "safe" build more less.
Old Sep 28, 2010 | 02:02 PM
  #40
Ferretts's Avatar
I don't think the sleeve will be a problem even after a turbo swap. and if the sleeves were rated to 400BHP then why wouldnt every tuned TC be blowin sleeves?
I have not heard of one person to blow up the sleeves on an lnf block or even an lsj.
I really do not care what gm bean counters say. It takes alot to **** up a sleeve, usually over 1000 hp, and im not gonna be anywhere close to that.
Old Sep 28, 2010 | 02:03 PM
  #41
Black SS/SC 06's Avatar
troof haha
Old Sep 28, 2010 | 02:06 PM
  #42
elecblue06's Avatar
not true.. there are a few LSJ's that have fucked up sleeves
however.. that being said.. people are using lnf blocks as a "cheap" alternative to sleeving the block.. soo what does that tell you
and john there actually is misinformation as well as being "cautious"
Old Sep 28, 2010 | 02:21 PM
  #43
Yeah? That's the gay. What sort of misinformation did GM put in their own build book? I'm not doubting you by any means, I'm honestly just curious.... considering they design the motors and all..
You ever figure out what you're doing with your setup btw?
Old Sep 28, 2010 | 02:29 PM
  #44
Well unless these LNFs are freaks of nature... A sleeve won't magically explode. Properly installed sleeves will take WAY more than 400hp... plain and simple. I was merely suggesting them because every time you replace pistons you have to grind into the cylinders to hone out the ring wear. A sleeve just prevents this because you can just remove the sleeve.
Old Sep 28, 2010 | 02:38 PM
  #45
Terminator2's Avatar
As far as machining, i have no idea what the tolerances are. The guy that built my brothers supra motor the second time is building my motor, and that car is pushing 900+ to the wheels and doing 213 in the standing mile, so i have faith that he knows what he is doing, but im hoping not to resleeve.
You might have to resleeve it depending on the damage to that sleeve. The ring lands will gouge into the cylinder and can leave some pretty good damage.
Old Sep 28, 2010 | 02:54 PM
  #46
BYT*SS*TURBO's Avatar
You will def want to go with a bigger turbo instead of trying to force HP with this turbo, my .02
Old Sep 28, 2010 | 03:24 PM
  #47
Ferretts's Avatar
well then, do you have 3500$ i can borrow? Or i can try to convince zzp to sponsor me
Old Sep 28, 2010 | 03:42 PM
  #48
elecblue06's Avatar
sign on aim hooker
Old Sep 28, 2010 | 05:20 PM
  #49
tomj77's Avatar
Originally Posted by myfakeevo
honing depends on the size of piston he has, normal is .10 or 1/10th of the bore of the cylinder. its basically to restart/refurbish where the pistons sit.
the original pistons made a groove, and now that groove needs to restart.
if he wants bigger, .2 or .3 im sure he has to re-sleave the block.
(ive never looked into rebuilding the lsj, or lnf, this is all speculation)
the rods have to be balanced. that means that each piston and rod weighs a little different and they have to be balanced to flow perfectly together otherwise you have a rough idle motor and its just not good in the long run.
most honing costs aroudn 200 dollars. new sleave install will probably cost a little more.
so basically get someone else to do it. lol
Old Sep 28, 2010 | 05:45 PM
  #50
cardelino18's Avatar
this happend to me and i had to sleeve my block... ring land got some pretty good scratches on my cylinder wall that if i bored out the walls would be too thin...
