lnf low boost help
Old Feb 22, 2014 | 07:15 PM
Smoke_ss's Avatar
lnf low boost help
I put back my lnf head and I only.boost.7psI and.sometimes.has hard starts... I get p0342 and p0117 codes..
Is there a way to reset cam.sensors or are they f**ked? I cant get my car to read them and can that cause low boost... I have no boost leaks by the way
Old Feb 22, 2014 | 08:27 PM
Powell Race Parts's Avatar
plugged cat i am guessing. shot in the dark.
Old Feb 23, 2014 | 02:47 PM
SSlobalt's Avatar
You put back your lnf head? You mean you replaced the head?
Old Feb 24, 2014 | 12:28 AM
Smoke_ss's Avatar
No I replaced a valve then put it back together
Old Feb 24, 2014 | 08:30 AM
SSlobalt's Avatar
Apparently, these cars are very hard to time correctly. PM nfamous and ask him if your issues sound similar to some of his old issues.
Old Feb 24, 2014 | 07:57 PM
Smoke_ss's Avatar
Yea hes actually my.buddy but.he doesnt have a # so ive been trying to get a hold.of him
Old Feb 24, 2014 | 09:02 PM
you need a service tool and do it right. set the bottom crank key dimple at 5 o clock and set the cam gears with the tool in place, then position the colored links and install the chain on the inlet cam gear first, then to the crank gear and then to the exhaust gear. as you put the chain onto the exhaust gear the crank gear will move to tdc at the keyway. install timing chain tensioner, remove service tool, you are done ( that part of it)
Old Feb 25, 2014 | 01:37 AM
Smoke_ss's Avatar
I followed the instructions from the dealer but.might of skipped a.tooth cause of.the tensioner... I doubt it though car sounds fine and doesnt idle
Old Feb 25, 2014 | 06:35 PM
huckernage's Avatar
if plugged you ll boost higher. i may be wrong about that someone told me that
Old Feb 25, 2014 | 06:53 PM
two things. If its really plugged it wont boost higher it will go into limp home (8 psi) but if he has codes for cam actuator solenoids, which he does, he has the cams timed wrong, it will run fine it will idle great it just wont go fast as it has that cel.
re time. is all. and ifyou did not use the service tool its not right. My .02 c
Old Feb 27, 2014 | 02:21 AM
Smoke_ss's Avatar
Damn thanks I hope you are right will definitely re time it
Old Feb 27, 2014 | 07:46 AM
this is a stupid price for the tool, but it is what you need to install timing chains correctly. Its almost impossible for an unlicensed/untrained/non tech to time the vvt without it.
http://www.ebay.com/itm/KENT-MOORE-TOOL-EN-48953-ECOTEC-ENGINE-CAM-PHASE-RETAINER-WITH-BOLTS-/271345580815?pt=Motors_Automotive_Tools&hash=item3f2d74fb0f&vxp=mtr
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
OPCrer
Sep 27, 2015 08:11 PM
