LNF Oil Capacity Issue.
Old Jan 17, 2012 | 04:22 PM
Shanedude's Avatar
https://www.cobaltss.net/forums/08-1...pacity-222430/
Okay so I had a little debate with the dealership today because I've noticed they've been charging me for 6L of oil on my past few changes, compared to 5L before on past bills. I remembered reading a thread on here awile ago (posted above) that says the LNF takes 4.7L, so I argued them relentlessly holding my ground at 4.7L, I got various answers that it should be anywherer from 5.3L-5.8L. Further debating and we discovered the GM Book saying 4.7L. They made me drive in and check the oil in the garage, It was reading high on the dipstick and they had to remeasure a few times. They also said it currently had 5.5L in it, I had it changed last friday.
Am I right here or is it over 5L? I'm thinking maybe because when hey changed it last time it was left overnight with them and the oil was cold, compared to today when my engine was at operating temp, driven for 20 minutes beforehand. It's synthetic mobil 1 aswell.
Anyway I've made a deal for $20 per oil change as long as I bring in my own oil/filter. Works out good for everyone. Oh and my headlight is being replaced free of charge too due to water leakage
Old Jan 17, 2012 | 04:34 PM
umrdyldo's Avatar
LSJ took 6.5
LNF takes 5
End of thread. Should not be charged for 6 at all.
Oh and $20 labor to change oil seems ridiculous. With **** tools I can do it in 30 minutes in my apartment complex.
I normally change on a lift in 10 minutes. That's some high ass labor.
Old Jan 17, 2012 | 04:39 PM
HyperMuffin's Avatar
Standard dealer rate 100$/hr.
.4 flat rate time for an oil change
40$ labor. I'd say 20$ with you supplying the oil/filter is about right.
Old Jan 17, 2012 | 04:44 PM
09BlueBaltSS's Avatar
Ya they've been screwing u for 1qt each time
Old Jan 17, 2012 | 04:49 PM
383_Stroker's Avatar
Originally Posted by umrdyldo
LSJ took 6
LNF takes 5
My bone dry lsj took 7.. and it takes about 6.5 on changes...
Old Jan 17, 2012 | 04:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
LSJ took 6
LNF takes 5
LSJ takes 6.5 quarts
Old Jan 17, 2012 | 04:57 PM
umrdyldo's Avatar
Cool, edited so people won't get confused or upset.
Anyways OP. Show them the book and tell them to check the damn dipstick after 5 qts.
Also you might want to get ACDelco filters so they don't bitch about that.
Old Jan 17, 2012 | 05:00 PM
Powell Race Parts's Avatar
^^^^ this. 5 litres is correct
Old Jan 17, 2012 | 05:04 PM
Shanedude's Avatar
Thanks for the responses. Glad to know 4.7 is right. Wondering if I should drain a bit since they said they put in 5.5L...
And I would do it myself or take it to my old boss's shop where I used to work years ago but I like having a legit oil change with paper record incase warranty issues arrive. Getting it done at the same places w/ paper trail will come in handy. When I was debating I had all my records in a folder, along w/ recipts. Helped my arguement quite a bit.
Old Jan 17, 2012 | 05:15 PM
umrdyldo's Avatar
I figure with a good log book and mileage and a good witness I would have no problem proving proper oil change. Although it's so easy to blame directly on dealer if anything happens.
Old Jan 17, 2012 | 06:24 PM
PrincessTurbo's Avatar
to get it to show full on the dip stick with a brand new oil filter completely drained 5.5 is accurate.
I've never gotten the dipstick to show full using under 5 liters period on a flat surface.
Maybe my oils thinner up here .
Go ahead and drain your oil, I would go by what the dip stick tells me , not the book .
Your mechanic is going by what he or she poured into the car to reach the full indicator level.
Like I said I've NEVER gotten it to read completely full using 4.7 liters.
Old Jan 17, 2012 | 08:10 PM
Shanedude's Avatar
Princess why quote me and not the multiple other people saying 4.7-5L...Maybe touch subject elsewhere like when I asked if Oil fluctuates when changing Hot vs cold? I need more info bro.
Old Jan 18, 2012 | 01:08 PM
sponge14's Avatar
I always purchase the big jug of oil when I change mine. They are 5q. The oil level always shows right at the high end of the dip stick.
Old Jan 18, 2012 | 01:19 PM
CrateEngineDepot's Avatar
check you owners manual (in front of them) parts cataglog
5.0 Qts or 4.7L
2.0 with filter
Old Jan 18, 2012 | 01:23 PM
damastah's Avatar
LOOOL!! my friend who does oil changes always asks parts guy for a box, which is 6...
and keeps 1 for himself... now has about 2 whole shelves of his toolbox... all bran new oil!
can only pull it off on cars like LNF, and others
Old Jan 18, 2012 | 02:04 PM
Shanedude's Avatar
I know there are like what 5 different motors in cobalts? but I didn't expect to get so much resistance that it is 4.7-5L.
PrincessTurbo I don't know what to think about your previous post it goes against everyone else here
Old Jan 18, 2012 | 07:47 PM
the only eco engine in cobalts that has 6.5 capacity is the LSJ it was to conform to EU extended drain interval requirements and therefore needed more oil capacity.
All the other motors are 5.0
I use quarts and litres interchangeably, so makes no nevermind to me.
For racing with a wet sump we fill non s/c to 6 litres. s/c stay the same at 6.5
the pans are different in the interior makeup, lsj to lnf and le5 et al; LE5 is significantly better in slosh control than the LSJ on a road race track.
the overlay looks like this
LSJ in foreground. difference is evident
but the hardcore powell pans for racing are trap door pans.
or dry sump
Old Jan 19, 2012 | 07:56 AM
themacguy's Avatar
So the stock LNF pans are no good for the track?
And if using stock LNF pan on the track = put in an extra 1 litre?
Confused again...
Old Jan 19, 2012 | 10:41 AM
Confused again...
stock lnf pan better than lsj pan for track. overfill 1 litre. trap door pan easy insurance not a lot of money 350 exchange...dry sump 3500
Old Jan 19, 2012 | 12:20 PM
themacguy's Avatar
Oh boy. Another PRS part to buy!
Old Jan 19, 2012 | 12:48 PM
Permafried-'s Avatar
Dealers refuse to listen, I had the same problem when I took my TC in for the first oil change, they put the same amount in as the SC and kept telling me the manual was wrong. I forced them to let the car sit idle in the shop for 30 minutes, check the dipstick and sure enough they grumble "remove 1L that's way too full". Funny, since then no one mistakes the LNF for the LSJ @ that dealer
Old Jan 19, 2012 | 01:11 PM
Shanedude's Avatar
Haha so this has been a problem is happening more then we thought, or maybe it's an Ontario thing eh Permafried :p
And does powell mean if you go to the track THEN put in an extra litre...or if you have this "trap door" thing you could put in the extra?
Old Jan 19, 2012 | 02:59 PM
themacguy's Avatar
If you buy the trap door pan, I don't think you require the extra litre. If you have the stock LNF pan = add 1 litrre for track use.
Old Jan 19, 2012 | 05:34 PM
Shanedude's Avatar
So why not run that much oil all the time if an extra litre has no negitive effects...
Old Jan 19, 2012 | 06:56 PM
silverSS08's Avatar
Last 2 times I've changed my oil it required a little more than 5 quarts. I think like 5.2? But they didn't charge me extra
