LNF Rear Brake Squealing
Old Aug 29, 2014 | 06:27 PM
YelCal7's Avatar
Hey Folks, I had replaced rear brake pads, and rear rotors. Still squealing like a BITCH! Pisses me off! I am very frustrated with rear brake. I had replaced brake pads twice, and I did lube the rear brake calipers bolts already. Am I missing something here ?
Old Aug 29, 2014 | 06:30 PM
footballplaya3k's Avatar
While braking or not?
Old Aug 29, 2014 | 06:35 PM
YelCal7's Avatar
While braking and turn to right squealing like a BITCH! Very Loud! I noticed people looking at me. When I turn left, it's quiet. It's very weird.
Old Aug 29, 2014 | 07:43 PM
YelCal7's Avatar
Bump! Anybody know what's the problems ? Or I'm better take it to Stealership ? SMH
Old Aug 29, 2014 | 11:20 PM
Wired's Avatar
Grease back of pads or use disc brake quiet by CRC.
They shouldn't be squealing really.
Old Aug 30, 2014 | 08:54 AM
cw383's Avatar
Mine squeal like a school bus stopping first time in the morning, then its good for the day. Someone here once explained to me its a micro layer of rust that forms on the rotor thru the night and you have to burn it off. Not your problem obviously, but I just wanted to add for those reading.
Old Aug 30, 2014 | 03:03 PM
slvrred-'s Avatar
Make sure you have the "tit" of the pad on that side inside the groove on the piston in the caliper. Otherwise it will drag all the time and most likely make that noise. I'd start there.
Old Aug 30, 2014 | 03:41 PM
YelCal7's Avatar
Found the issues, It's the emergency brake! It's tight as hell! I had to loosen it up, now it STOP squealing! No more squealing, I think that is the issue why some LNF owners are very frustrated with their rear brake squealing. I'd go from there and check out with your emergency brake.
Old Aug 31, 2014 | 01:25 PM
SSlobalt's Avatar
Yeah, a lot of members just keep tightening up the emergency brake adjustment when the e-brake stops holding. The problem is actually the caliper piston not returning to the reset position. If you were one of those people that tightened your e-brake cable, when you put on new pads and "reset" the piston, the e-brake was so tight that the piston put a bind on the cable.
Damn if the rear calipers on these cars aren't the biggest hunks of **** around.
Old Sep 3, 2014 | 09:56 PM
YelCal7's Avatar
Update: Yep! Here we go again back to step 1! It's squealing like a pig! I tried switch new brake pads still end up the same thing! I did compressed brake caliper and I opened up the bleeder to bleed the brake while compressing the caliper. This caliper is FUCKED UP! Will not compressed all the way back down. It will only compressed about 1/8 that's it, I think this is the reason why due to that ******* had tighten up the emergency brake and not allow the brake compressing while braking. Cause it only move 1/8 back a and forth and it's not let it off freely. I had tried to force compressing counterclockwise and it stop there. I have to get new caliper cause this caliper will not budge at all. Pisses Me Off! Sigh...
Old Sep 29, 2014 | 01:46 PM
importkiller's Avatar
Just making sure, you were using a compression tool that rotates and compresses at the same time right? with the little notches that line up with the piston?
Old Sep 29, 2014 | 06:18 PM
tomj77's Avatar
Mine does the same crap. Mostly when it's wet or after it gets wet for a few days. Brake boost for a few seconds and it will go away lol
Old Sep 29, 2014 | 06:33 PM
YelCal7's Avatar
Then it'll come back anyway.
Old Sep 29, 2014 | 06:41 PM
tomj77's Avatar
it stays away for a while. iv greased everything u should and it still squeals. those hawk pads maybe.
Old Sep 29, 2014 | 06:47 PM
YelCal7's Avatar
I had put so much grease in it anyway. Even I put high temperature grey grease on the edge of brake pads and back of it. Still don't work! GM pisses me off!
Old Oct 1, 2014 | 05:13 PM
umrdyldo's Avatar
Hmm you sure you used the proper brake tool? I also found that if I twisted it the decompressed it completely then compressed it, it would compress much easier.
Old Oct 1, 2014 | 05:38 PM
YelCal7's Avatar
YEP! I have c clamp for brake to press the pistons back then slot in new brake pads in. I've done it many times.
Old Oct 15, 2014 | 04:05 PM
SSlobalt's Avatar
No c clamp on rear calipers, my man. You have to twist the pistons clockwise, slowly, while applying pressure. There is a special tool for it but it can be done with some large, straight, needle noise pliers.
Old Oct 15, 2014 | 04:20 PM
YelCal7's Avatar
Yup! Like this 1 that I already done that.
Old Oct 15, 2014 | 04:28 PM
This on a C-clamp isnt going to rotate it correctly. I also forget if the rears are clockwise or counter-clockwise rotation
Old Oct 15, 2014 | 04:42 PM
YelCal7's Avatar
I did it without C-clamp and realized it's not working. So, I had to get this special tool to decompressed it. When I turn it clockwise it won't decompress then I had to do it counter clockwise about half way then turn it clockwise then it finally decompress. I had replaced pads and rotors. Still squealing ever since...I've been dealing with it everyday when I'm driving my car.
AaronJ's Avatar
When I bought my 09 SS new, the rear brakes squeeked all the time for the first 8k miles. Then I took the car to Road America. A couple of 20 min track sessions later, routinely braking from 120+ mph (even 140 mph into turn 1) down to 60, and the rear brakes never made a sound again .
Old Oct 15, 2014 | 06:00 PM
SSlobalt's Avatar
Yep, OP. You need a new caliper.
Old Oct 15, 2014 | 06:16 PM
YelCal7's Avatar
That's what I thought...Sigh...
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
