LNF Running Temp ?
Does your car possible run cooler due to your tune ? Or any of your mods ? I had always read that the tc's run rich. And that cars that run rich have a tendency to run a little cooler. Is that right at all ? Cause if so then you would think I tuned lnf would run hotter then a stock lnf ? Does that make sense ?
With hotter outside temps the oil temp will always be a bit hotter than your coolant, also the oil temp readout is simply a formula since the engine doesn't have an actual oil temp sensor.
Didn't know, but now I do, thanks
z28addiction
09-28-2015 12:03 AM
