LNF stock pistons?
Old Apr 1, 2010 | 01:57 PM
09BlueBaltSS's Avatar
Looks good to me. That manifold is cracking all to hell tho
Old Apr 1, 2010 | 02:02 PM
ItalianJoe1's Avatar
Where??
Matt, any chance I can get a closeup of an LNF stocker from you guys? Like, straight down the spark plug hole, center of the piston area.
Stamina's Avatar
I've got them on my pistons.
Old Apr 1, 2010 | 02:07 PM
Cool, so it's normal then. Just wanted to verify.
What happend to #3 wall on yours?
Old Apr 1, 2010 | 02:08 PM
Matt M's Avatar
Stock LNF Piston-
Old Apr 1, 2010 | 02:10 PM
Wangspeed's Avatar
It's supposed to be like that, to keep it from warping.
Old Apr 1, 2010 | 02:13 PM
Terminator2's Avatar
Yep looks normal to me. You going to set his ring end gaps a little wider than stock Joe?
So its cut like that? They look a little jagged hence me saying cracked.
Originally Posted by Matt M
Stock LNF Piston-
Ok... so those marks aren't there.
Now i'm confused.
Stamina's Avatar
Scoring.
Dealer says it's within tolerances though when I showed them, and haven't had any issues with it.
I'm planning on eventually opening it up to do some work/mods, so I'll probably fix that then.
Old Apr 1, 2010 | 02:15 PM
  #36
Always. He's planning on a lot more power, so i'll adjust accordingly.
Between ports you mean? No, they are seperate from the factory. Cuts down on cracking actually.
Last edited by ItalianJoe1; Apr 1, 2010 at 02:15 PM. Reason: Automerged Doublepost
Old Apr 1, 2010 | 02:17 PM
  #37
Stamina's Avatar
For future reference, how much gap is stock and how much more do you need to add per additional HP goal?
  #38
Good thinking GM
Old Apr 1, 2010 | 02:21 PM
  #39
Originally Posted by Stamina
For future reference, how much gap is stock and how much more do you need to add per HP goal?
No idea on stock gaps, probably in the low teens. For a baseline, you want to figure about .0045-.0055 per inch of bore size on an average engine (performace). If you plan to run lots of boost, nitrous, or exotic fuels, i've seen up to .0065/in recommended. So for our 86mm bores (3.5in for arguments sake), you are looking from .016 to .028 depending on your specific application, pistons, power goals, and personal preference. There will also be a debate on how to stagger the gaps (whether first or second ring should be the bigger gap), but that discussion is all for another thread. Read up on it a little online, there's a ton of info out there.
Old Apr 1, 2010 | 02:24 PM
  #40
BLAZIN07SS's Avatar
I'm too JDM for you
okay his piston definitely looks different. there is like an extra set of exhaust valve reliefs near the bowl area
Old Apr 1, 2010 | 02:29 PM
  #41
Staimna's
Stock LNF Piston-
I see them on Stamina's motor, but not the OEM pic ZZP posted. Possible they are just whacking into the pistons under boost? Pistons are much softer than the valves, and if you were running the car hard at the time when it happened, it's feasible that the piston would just yeild and no real damage would result.
Old Apr 1, 2010 | 02:34 PM
  #42
Wangspeed's Avatar
There's yet to be a pic where there is evidence of valve to piston contact in this thread. Blazin07ss, pics or GTFO!
Old Apr 1, 2010 | 02:38 PM
  #43
Maybe the valves are floating a little at high boost. Fabian and Matt were both running a lot of boost. What about Stamina?
Old Apr 1, 2010 | 02:41 PM
  #44
BLAZIN07SS's Avatar
I'm too JDM for you
the only pics i have are the same as joes. i was there when he pulled the head
Old Apr 1, 2010 | 02:45 PM
  #45
Wangspeed's Avatar
Not possible.
Oh, I didn't realize you guys were talkin about the same motor. Take some better pics!
I know the area that you're referring to, but it just looks like gunk in these pics.
Old Apr 1, 2010 | 02:46 PM
  #46
Stamina's Avatar
Normally, no. Mine usually topped at 22-23psi, but I remember one occasion it wandered up to 26 during an extended run.
Old Apr 1, 2010 | 03:23 PM
  #47
It is just the angle in the pics.
Old Apr 1, 2010 | 04:57 PM
  #48
The reliefs are definately there.
The ZZP pic is NOT a stock piston. Look at the bowl area. Stock is round, the aftermarket one is square (ZZP).
Old Apr 1, 2010 | 05:02 PM
  #49
peachpuff's Avatar
This one looks square too and its from gm.
Old Apr 1, 2010 | 05:06 PM
  #50
Agreed. Wonder if the Cobalt LNF has different pistons for some reason?
Tag for that pic says sky redline.
ZZP, was that piston a FWD LNF piston?
I'm getting slightly interested in this now, maybe piston design changed at some point?
