LNF tensioner maintenance
Old 08-26-2014, 07:21 AM
r3v07ut10n's Avatar
I guess this is why i will be changing mine every year for good preventative maintenance. $50 is cheap for peace of mind. I believe these are 1 of the culprits for timing chain stretching as well.
I installed a brand new one last year when i upgraded the valve springs. Not even 5k on this.
Old 08-26-2014, 07:37 AM
raver0789's Avatar
Did you install this yourself?
Old 08-26-2014, 08:05 AM
Administrator
Administrator
Staged07SS's Avatar
I'm sorry but if u install the tensioner correctly, there is no way in hell you would need to replace one every year.
Old 08-26-2014, 09:19 AM
r3v07ut10n's Avatar
Installed by GM certified technician directly after we did deluxe timing kit and valve springs.
Old 08-26-2014, 09:57 AM
taintedred07's Avatar
What valve springs?
Old 08-26-2014, 09:58 AM
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by taintedred07
What valve springs?
Good point. Super heavy springs are known to put a lot of strain on the chain and valvetrain.
Old 08-26-2014, 09:59 AM
But what's considered heavy? ZZPs 82lb springs?
Old 08-26-2014, 10:22 AM
Administrator
Administrator
Staged07SS's Avatar
Nah. 94lbs and up would be heavy.
Old 08-26-2014, 10:27 AM
Haven't heard anyone running above 82s lol
Old 08-26-2014, 10:28 AM
Would the occasional over-rev be a cause for replacement on a LNF (ei 7000rpm stock valve train)
Old 08-26-2014, 10:37 AM
Imo you're pushing your luck. If you have the top end(turbo swap) then upgrading springs would be wise to rev out to 7400rpms to take advantage of the extended powerband length.
Old 08-26-2014, 10:38 AM
Administrator
Administrator
Staged07SS's Avatar
There are supertech 94 lbs springs for the ecotec. I've seen an lnf or two with them.
Not sure if on here though.
Old 08-26-2014, 10:48 AM
I'm only running the KO4+ so a little more top end. I need to just pony up and buy and build a head
Old 08-26-2014, 11:37 AM
r3v07ut10n's Avatar
Supertech #78's red line @ 7200, rarely go there. Could be just a bad part, looks as if the moon clip broke, cause it cant be found.
Old 08-26-2014, 12:41 PM
raver0789's Avatar
The missing part will probably be in your oil pan.
Old 08-26-2014, 12:45 PM
r3v07ut10n's Avatar
yah this is what john and i thought as well, no issues. Now only if i could get my tuner to give a new date LMAO
Old 08-26-2014, 12:56 PM
user 72239's Avatar
I rev to 7000 with the ZFR
93k miles on mine.
Old 08-26-2014, 01:06 PM
raver0789's Avatar
I think it's been a record 5 days since he has texted me last.
Old 08-26-2014, 06:49 PM
If you're staying on the k04+ then just keep stock valve train and rev to 6800-7000rpms. But if you plan on turbo swapping in the future then upgrading valve springs are a good investment.
Old 08-26-2014, 09:21 PM
blrt's Avatar
I am on the his list too understandable he's super busy I guess? I just need a minor check on the tune nothing major. Doesn't justify driving a total 11 hrs to MI to have this done.
Old 08-27-2014, 02:11 AM
Omiotek's Avatar
stock springs should not be run passed 6500. even thought theres a lot of people out here they are not designed for that type of load.
if you want to rev out to 7 do valve springs. the k04+ is really pretty much out of steam at anything passed 6700. a built head will benefit anyone if its done properly
also its NOT uncommon for those retainer clips to break and thats probablly what happened to your tensioner. we have had them let loose at speed and ont he track believe or not. we usually put a couple tack welds on them or you can put a small amount of jb weld in a section to help keep the clip in.
Old 08-27-2014, 07:31 AM
r3v07ut10n's Avatar
Thanks for the advice, if it happens again i will put a bit of jb weld on.
Old 08-27-2014, 09:14 AM
The only time I rev out to 7k is 3rd gear at the track so I dont have to shift into 4th, or I have a ******* attack and rev it to 7k in 1st a built head is in the future, havent given much though to it yet. Def interested in the timing information and the trick for the retainer clip
Old 08-27-2014, 12:48 PM
user 72239's Avatar
but but....I like revving to 7000 now that i have a turbo that can handle it
Old 08-27-2014, 03:13 PM
Get the springs in and rev to 7400
Quick Reply: LNF tensioner maintenance
