LNF Valve Gunk = Misfires?
Just wanted to share this with everybody..
I know about the valve/seat "gunk" could be a problem, but just wanted to know if anyone as ever seen a problem like this on the LNF in the past?
Yesterday, out of the blue - I had some trouble with misfiring, it would misfire once in awhile, and it only happens when driving around 20-35 mph - seems odd - but it's not constantly? Checked for codes found the MAF sensor was faulty but no misfire codes? So I pulled the plugs [AC/Delco] and each one was brown and the porcelain is white/tan. So I ordered new plugs and MAF sensor to see if this could resolve it [not to turn it into parts monster], but has anyone seen anything like this before? I checked the gaps on all of them, all are at 30..
Also, since the spark plugs were out, I figured why not do a compression test, found Cyl#1 @ 114 and the rest Cyl#2 to 4 were at 125.. [yes, each cyl is at TDC] By the book it should be at 120 to 128, without the 20% rule.. Has anyone found any issues with the piston rings or the head gasket in the past with similar compression test results on the LNF?
I ask because - I have found on a few Ecotec's I've worked on already, the rings have been "eaten" from either hot spots, worn ring or landings with cyl wall scarring or ECM running the engine in a rich condition b/c of a faulty MAF sensor - even though the test results shows MAF sensor works, but the return signal voltage was off by .06mV compared to brand new MAF sensor.. and only once, I found the head gasket to be "eaten" too from a hot spot which caused low compression reading.. odd stuff..
Well.....
I broke ringlands on two pistons. My compression test was like this.
146, 126, 138, 30
30 is obvious. The 126 that I bolded because it's in your range that you listed also had a broken ringland. The piece hadn't come out yet. When the piston was removed it was found to just be floating there between the rings.
146, 126, 138, 30
Yeah, I would say average would be 150-160 (i.e., pretty healthy). As long as you don't have [more than] around 10% psi variance between cylinders, you're pretty straight.
Yeah, 150-160 was what all of mine read on my last compression test and I'm just a few hundred feet above sea level.
Someone should make a Cobalt SS/TC compression test how to video so we can point people there regularly haha.
That said, I need to do one, if I remember correctly a year ago I was at 155, 155, 155, 155 and I'm 6000ft above sea level
yep, I check again this afternoon, #1 @ 116 and the rest of the cyl's at 128.. hopefully next week I'll get to drop & strip the block clean and get a few nice goodies, since it's going to be out of the car..
i'm at 300 feet above sea level..
either way I look at it.. but atleast i have a few options now..
Well.....
146, 126, 138, 30
146, 126, 138, 30
thank god - i have a good sense of humor to all of this...
patooyee
Oct 1, 2015 01:07 PM
