Lnf won't boost
Lnf won't boost
so did a pull with some random lightning that wanted to run on my way home from playing basketball and after the one pull I beat him but my car wouldn't go into boost anymore I looked at all the clamps and the intercooler looks good as well. The pull was like a 40 to about 100 my mods are bone stock with a trifecta tune at 23psi somebody help please!!!
Underboost? Did you throw a code? Mine did that a couple times before I had the tune logged and retuned. It is bitchin now but maybe you had the same problem. I would turn my car off then back on and it would work just fine.
boost leak. I had it once as well and thought it was something else because I couldnt find a loose clamp.
Turns out I cracked the lower charge pipe by the lower MAP sensor right where the nipple is for the vacuum hose. We all know how hard it is to get a good look at that part of the car without taking it apart...
patooyee
Oct 1, 2015 01:07 PM
