Lots Knock Retard
I have seen this happen when something is rattling really hard on the car, like exhaust or lower charge pipe. Does your car have a jarring rattle? at 12* you are just pegging your knock sensor feedback. Very unlikely that you would have that much detonation on the stock tune too.
Its better but its not 100 percent.
There is 3.7 degrees of knock on cylinder 1
The knock on all the other cylinders is gone and it only happens below ~4k, doesnt go up with rpm just shoots to 3.7 and starts going down to 0.
I took off 6 degrees of timing and there was no change.
I will take a look if something is rattling but I am not worrying about it.
On the graph you see an instant jump to 3-3.7 KR, maybe flat for a bit then falls to zero as RPM climb.
I was only able to rid myself of that type of KR by tuning the fuel trims and adding about 25% ethanol.
Put the timing back to the way it was. Start by tuning fuel trims. Once your fuel trims are decent, then remove timing as needed.
Yup, it goes to 3.7 stays for a bit then starts to drop.
I am injecting meth at 3psi to full flow at 15psi (375cc nozzle) and it still shows 3.7. It shows the same 3.7 in the same spots if I turn the meth off. I am going to wrap all of the pipes and add rubber feets to a few things to see if it helps.
But I am not too worried about it.
FYI.... Random bits of knock isn't always a condition of ignition timing when it comes to the lnf.
That has to be one hell of a long lap and one hell of a small tank to run out in one lap my man.
I have cars running auto cross tracks on 25gph (more than double the nozzle of what sev is using) and will make it through an entire event on less than a gallon.
Where is your nozzle located sev?
I have the reservoir that comes with the snow performance kit, it's rather small.
The light to refill comes in rather quickly, about 6 0 to 120 pulls and it needs to be refilled.
Nothing special on the nozzle location, after the tmap.
My downpipe exploded again today, should have kept the zzp pipe since that one never gave me any issues.
Well ****. That kills my theory on you chewing through meth then.
I sort of figured. I just didn't want to assume in hopes that I'd have a simple resolution to his meth consumption.
