Lots Knock Retard
Old May 19, 2016 | 01:33 PM
  #76
yellow dragon's Avatar
I had high meth consumption on my aem kit. The check valve had failed so it was pulling in meth even on vacuum pressure not just on boost. I ended up buying a snow performance solenoid (then hooked up the wires wrong so it was stuck open..dumass) once I fixed that it has been good.
Old May 19, 2016 | 02:05 PM
  #77
sev's Avatar
sev
A friend is fixing the downpipe for me today, when it's back i will take a look at the check valve to see if its failing.
Old May 20, 2016 | 08:02 AM
  #78
blueLNFftw's Avatar
Just disconnect the line and plug the hole. If your issue goes away than you know you have a meth malfunction.
This is why I dont run meth anymore. Too much extra BS to worry about.
Old Jun 10, 2016 | 07:19 AM
  #79
sev's Avatar
sev
On regards to my 3.7 degree knock on cylinder one.
I am going to try and rotate the sensors again just to see if there are any changes.
I was talking to a buddy yesterday that mentioned putting rubber O rings around the knock sensors of his motor.
Wondering if anybody heard of doing such thing before.
Old Jun 10, 2016 | 03:24 PM
  #80
blueLNFftw's Avatar
Yes, but you could potentially isolate them from a real problem.
Old Jun 12, 2016 | 12:11 PM
  #81
sev's Avatar
sev
The 3.7 degrees happen at throttle input even on neutral.
Turned the knock sensors and the neutral knock gone and knock at load was at 0 or 1-2 range.
However after about 5 miles miles of driving it came right back to 3.7 degrees.
Does it again even on neutral
I torqued it to 19 pounds.
Not taking all that apart again today but it am going to try 21 pounds
Edit
I fixed a boost leak but no change, so let me load the factory tune and see if anything changes. Before I pull all that off again.
Edit
Full ecu write to factory and knock is back at 0. Loaded the latest tune and knock still at 0.
Going for a long drive and hope for the best.
Old Jun 12, 2016 | 09:19 PM
  #82
D330's Avatar
sorry if I missed but are you stock bpv and vacuum lines? mine kept pulling timing cause of bad vacuum canister creating can of worms. If you havent tried the vacuum tank bypass aleady you should try and see if it corrects it.
Old Jun 13, 2016 | 01:19 PM
  #83
sev's Avatar
sev
I dont think the Kappa have that vacuum tank.
I have a forge bpv without the solenoid.
The knock is reduced.
The neutral knock is gone, still have some low rpm know that my be tip in.
However if it sits in traffic it will go back to the 3.7 jazz.
edacsac
Mar 19, 2016 11:56 AM
germbruhh
Mar 7, 2016 10:32 AM
CobaltHunter
Tuning
Mar 3, 2016 12:37 PM
xRedrumisBack
Tuning
Feb 23, 2016 12:06 AM
Tomcat801
Feb 17, 2016 03:47 PM
