low boost
Old Sep 7, 2010 | 09:25 AM
MaxPsi's Avatar
low boost
hey guys,
a few days ago i noticed i was only getting about 13-14 psi on my low boost setting....then it drops off to any where from 9-12.
is this normal? i have checked for boost leaks and found nothing.
i am byt tuned with a catted dp and charge piping...stock intake
Old Sep 7, 2010 | 09:28 AM
iboost's Avatar
whats the weather like where your at?
Old Sep 7, 2010 | 09:38 AM
MaxPsi's Avatar
high 70 low 80
Old Sep 7, 2010 | 09:45 AM
iboost's Avatar
is it humid?
Old Sep 7, 2010 | 09:46 AM
MaxPsi's Avatar
it was a little more humid when it first started so i blamed that. Yesterday it was not really humid at all...kind of cooler out and still same issue
Old Sep 7, 2010 | 09:47 AM
iboost's Avatar
humidity is sometimes my problem, but if thats not an issue i'd say it either have to be a slight leak somewhere or the tune. Get a hold of BYT...
Old Sep 7, 2010 | 09:48 AM
SSlobalt's Avatar
When you say you have checked for boost leaks, what do you mean exactly? Visual checks don't get you much. You need to do an actual boost leak test.
Old Sep 7, 2010 | 09:53 AM
iboost's Avatar
I was told some where, I can't remember where...but if you spray something like carb cleaner on vacuum connections and your car "stubbles" a little bit then you have a leak there. I don't know if this is true or not...
Old Sep 7, 2010 | 10:14 AM
MaxPsi's Avatar
i used a boost leak tester with soapy water
turbochargedss2012
Sep 20, 2023 12:17 PM
patooyee
Oct 15, 2015 05:11 PM
importkiller
Sep 30, 2015 07:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
OPCrer
Sep 27, 2015 08:11 PM
