low boost with catless dp
Old Jan 28, 2011 | 10:54 PM
bspeed's Avatar
I gota bone stock 2009 vic red ss/tc 14k and installed the badmab catless down pipe, and few days later threw the expected cel. now the only thing odd is the car wont boost up to the stock 13psi it only wants to boost to 6 maybe 7psi and no higher. help? opinions ?
thanks,
Bryan
Old Jan 28, 2011 | 10:56 PM
northvibe's Avatar
check the CEL to see exactly what error it is. Don't assume its the expected error cel. Maybe theres an exhaust leak? or a leak in the IC (cracked end tank), loose boost tube? Check the cel and see what it says.
09sscalicobalt's Avatar
what cel did it throw? ive had my megan on over a month and havent had any cels yet
Old Jan 28, 2011 | 10:57 PM
xcross's Avatar
did you buy a defouler?
Old Jan 28, 2011 | 11:00 PM
bspeed's Avatar
i will check the code tomorrow i cant find my reader as of tonight, or ill stop by autozone and post it up asap and yes i got the defouler but couldn't get it to fit right rubbing issue
Old Jan 28, 2011 | 11:11 PM
northvibe's Avatar
ok ya update us tomorrow
Old Jan 28, 2011 | 11:14 PM
xcross's Avatar
Mine was tight also, i just took a hammer and screw driver and modified the heat shield until it fit. still against heat shield but does not vibrate
Old Jan 28, 2011 | 11:18 PM
bspeed's Avatar
did your car boost low? without the trifecta tune?
Old Jan 28, 2011 | 11:27 PM
xcross's Avatar
No i did not. stock it boosted 15 psi and then with dp like 13. You very well might have something else going on besides this. From what I have heard boosting at 6psi is the ecu going into limp mode due to various reasons, hard to speculate until you find out what the code is.
Old Jan 28, 2011 | 11:34 PM
YelloEye's Avatar
In for results.
Old Jan 29, 2011 | 02:37 AM
MS3 2 SSTC's Avatar
thanks,
Bryan
I'm no expert but it might be because you're running on a stock tune??
Old Jan 29, 2011 | 03:49 AM
RyRidesMotox's Avatar
Usually the code associated with the dp won't cause limp mode... Mine didn't. It could be something completely unrelated.
Old Jan 29, 2011 | 09:25 AM
northvibe's Avatar
ya exactly....
Old Jan 29, 2011 | 10:34 AM
G Speed's Avatar
thanks,
Bryan
Nothing is wrong with your car...
Learn-Down!
I just looked at your location it's approx 0c... + you just added in a downpipe.. which is suppose to make a decent amount of hp
It sounds to me like it's just learn down in action...
Colder Air = More Power = Learn Down = Less Boost
Catless Downpipe = More Power = Learn Down = Less Boost
But still check the cel...
Edit: Stock you should be able to boost alot higher than 13psi.. "did you just get this car in the colder months"
Old Jan 29, 2011 | 10:38 AM
turbohornet88's Avatar
could be because of the weather too. My car seems to boost slightly lower then 13. It kinda happened when i put my catless on too.
Old Jan 29, 2011 | 10:54 AM
bspeed's Avatar
hey guys i got the code this morning found the code reader and here it is
P2187 "system too lean at idle speed" (bank1) <---only code that came up
DTC
catalyst mon - inc
evap system - inc
oxygen sensor- mon inc
like i said its really cold here in pittsburgh, i got the car back in october during 40 55 degree weather and it normally boosted like 13 14 psi maybe it is the cold weather. the car picks up good but just wont boost any higher that 6psi
thanks
Old Jan 29, 2011 | 10:57 AM
Cefaln452's Avatar
evap shouldnt be coming up...
you should only be getting a catalyst efficiency code
disconnect your battery for 20 mins then try again, should learn it... you may have jut thrown the fuel trims off a bit
Old Jan 29, 2011 | 11:00 AM
Terminator2's Avatar
DTC
catalyst mon - inc
evap system - inc
thanks
You have a leak somewhere. 2187 lean off idle normally means a vac/boost leak.
Old Jan 29, 2011 | 11:14 AM
bspeed's Avatar
ok and how do i go about fixing this
Old Jan 29, 2011 | 12:03 PM
Cefaln452's Avatar
get a can or carb/throttle cleaner, spray around hoses and connections, when rpms go up... you have found your leak
Old Jan 29, 2011 | 12:09 PM
northvibe's Avatar
did you tighten DP bolts to the right torq specs? what about the o2 sensor?
Old Jan 29, 2011 | 01:56 PM
bspeed's Avatar
yes they are tightened no cracks or leaks that i can see i checked the hoses.
i noticed when i opened the hood the dipstick wasn't seated in and was sticking out a few inches
didnt do any thing different still low boost and the gaskets are like new
Old Jan 29, 2011 | 05:51 PM
bspeed's Avatar
well as of now went to apple bees with the gf and it boosted like crazy up to 15psi like it should , the only thing i checked was the dipstick it was sticking out an inch or so also had the battery unplugged for a while
Old Jan 29, 2011 | 07:30 PM
YelloEye's Avatar
You just reset the ECU and it hasn't had a chance to learn down yet. Good to hear that it's working normal again.
Old Jan 29, 2011 | 07:45 PM
importkiller's Avatar
sounds like learn down may be a factor here, get a tune.
