low boost with catless dp
Old Jan 29, 2011 | 08:01 PM
bspeed's Avatar
Originally Posted by YelloEye
You just reset the ECU and it hasn't had a chance to learn down yet. Good to hear that it's working normal again.
what exactly is do you mean by "it hasnt had a chance to learn down" is that good or bad? some type of stock system with the stock tune?
Old Jan 29, 2011 | 08:27 PM
importkiller's Avatar
The OEM tune will keep your car at approx 260 hp at all times. If the air gets colder or you put mods on that add power then your boost will go down, and if the air is warmer or you are at a higher altitude then the car will make more boost to reach target hp.
Old Jan 29, 2011 | 09:10 PM
MajorCB's Avatar
Originally Posted by importkiller
sounds like learn down may be a factor here, get a tune.
wonder if the GMS1 would fix this.. as it removes the learn down as well.. it just wouldnt give him as much performance from the DP since it doesn't tune for it specifically..
Old Jan 30, 2011 | 01:05 AM
rukkee's Avatar
6 psi sounds like there is something up with the wastegate ..... could be the actuator or possibly the actuator rod has lossened up . When the ECU can't control the wastegate for whatever reason .... The ECM will disable boost control and limit the system to mechanical boost only which is right around 5psi.
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Sep 27, 2015 08:53 PM
OPCrer
Sep 27, 2015 08:11 PM
