Low RPM bucking (misfire) no DTC
#51
Ours cars sputter and shift hard when you shift in mid to high boost pressure silly! Most Sticks ive driven in 5th gear at 35-45mph tend to make the motor work overtime! It's not highly recomended and will ruin ur motor over time!
#52
After reading and posting in the thread earlier yesterday and thinking about it on the drive home last night, I take back what I was thinking of 1500-2k rpm being too low for fifth. On flat roads and light throttle acceleration during gentle cruising around town it's not a problem, but if you're at 75% throttle or more and trying to accelerate hard it probably would be best to downshift. I'd still maybe try to get a scan tool on it but I doubt there's anything you'll find wrong on the car and it's probably just the engine calibration. If it's really bad you could always take it into the dealer but if they don't find any mechanical or electrical issues and it is the cal they aren't going to be doing anything if GM hasn't released a new flash to correct drivability complaints.
Psykostevo says that he has seen many LNFs that exibit this trait, and I am willing to bet that it is a calibration issue with the ECMs in a lot of these cars. Today it was much cooler this morning and I did not notice the issue as much.
#53
Im still a bit confused. My Sig has my mods. In low gear around 2000rpm I have a max knock of 3.6. And a small misfire. So would this be normal with all the power,about 315 whp and 340 wtq. Will this change at all after I do the ttr motor mount?
At higher speeds and rpms theres no knock or miss fire.
What do you all think?
I don't know if it makes a difference but my A/F 's around normally around 14.4-15. Do you think its to rich with vinces tune,my fuel trims are also wacked and all over the place.
Last edited by superbrowndude; 07-08-2010 at 09:58 PM. Reason: Automerged Doublepost
#56
So i've been tracking this issue. I even went so far as to do a datalog of it. While the software reports no knocking it reported 17 multiple misfires that I can see but wasn't throwing a CEL . I did my best to compensate for what I believed to be MAF sensor turbulance with tuning. I should have messed with AFR but I am not well enough with tuning these cars to **** with much yet. Although this time I had only a couple misfires reported. I really got to wondering about it so I took my plugs out and checked the gap (which is factory set at .036 straight form a brand new crate engine). I regapped them for .032, where I then made note I had a single misfire event, once again I gapped them for .030 and now I report no misfire events at all. Driving it seems smoother. Is there an issue with the ignition system or something I can program in that area for whatever reason I am not aware of? I know in some computers I can program for multiple spark events in one cycle.
#57
I believe it is the purge valve thingy. BYT had me unplug it so it wasnt working, it threw a cel but it quit doing it. I also observed that the afr's would jump to about 17-18:1 and quickly go back to normal. My buddie who is a gm tech said that when the valve opens it is like a metered air leak and it is not compensating for it like it should and is causing it to go lean and the missfires.
#58
I think my valves were sticking a little when the car was new. I no longer have that issue even lugging the car around in 5th at 40-45 mph (Gets 50 MPG and I do it only on flat ground, not many hills in Florida)
#60
Mine does it all the timr around 1700rpm... if you are at just the right load in 2nd gear it'll buck so hard its like the car cut off ans the started itself again....
#62
While this is a older post, Kudos to the guy who searched, found the thread and bumped it looking for an answer.
#63
does it sound like your car wanted to kill itself (shutdown), backfiring, and misfiring? just wonder if that was kind of related to my experience. my car has been normal for a week and a half.
#65
Did you find out the problem?
I have a 2010 cobalt 2.2 thats an auto and it does the same thing my autotech teacher told me to try buy new coils and i just spent $168 for nothing basically
#66
It's possible you have other issues, it could be the start of a failing MAF (don't just throw parts at it, test them), it could be issues with the transmission, and the list goes on and on.
boostbalt
09-29-2017 06:38 AM
