transmission experts needed
Old Sep 29, 2006 | 08:56 AM
vtecduster's Avatar
Can some of you guys that live, eat, and breathe cars for longer than I have please explain to me what the hell the numbers mean when talking about Gear Ratios. What I do know:
Pretty much nothing.
Do better gear ratios translate into more WHP?
Are larger or smaller numbers better in a gear ratio?
Thanks for your help peeps.
Old Sep 29, 2006 | 09:03 AM
NoRemorse's Avatar
higher number = hiher speed at a given rpm
lower number - quicker acceloration, but you run out of breathe fast.
It's just:
Whele RPM = engine RPM * gear ratio * final drive ratio
Old Sep 29, 2006 | 02:51 PM
Red07SSNA's Avatar
Have you ever riden a 10 speed bicycle? Is it easier to start in 1st gear or 10th? Easy to answer, right? Rear (Final Drive) end ratios act the same way. A street car uses a gear ratio that will give good MPG (2.53:1 to 3.91:1). A drag racer wants to get to the end quick and dosesn't care about MPG (4.10:1 to 5.14:1). It simply makes it easier (as in mechanical leverage) on the engine to accelerate. Overdrive transmissions have made it better in that you can have a "Low gear" (higher numerically) and still get better MPG. For example, I've driven cars with 2.53:1 ratio gears and it felt like I was towing a boat behind me off a light. Just changing the gears to 3.23:1 made the car quick off the line.
If you have two identical cars except that one has a 3.00:1 ratio and the other has a 3.90:1 the 3.90:1 equipped car will be quicker under acceleration. A VERY BIG misconception is that the 3.00:1 car will have a higher top end than the 3.90:1 car. This is not true in all cases -- top end speed is determined by horsepower NOT engine RPM. If an engine has a flat horsepower curve IE., 200 HP from 5500 to 6300 RPM then the gear ratio will not matter. The car with the 3.00:1 will run top speed at 5500 RPM and the 3.90:1 car will run the same top speed but will be turning 6300 RPM.
Not so easy to understand but it is a fact...been there, done that!
RaginChopsuey
Oct 27, 2015 01:27 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
