Lower charge pipe leak (Hahns)
I Ran ANOTHER boost leak test and finally found where the other leak was coming from my lower charge piping. There is a pin size whole in tthe aluminum piping, right before my Stage 1 sensor
1st question: Is it SAFE to run Hahns upper charge pipes with stock Lower piping?
2nd : is there stuff out there to seal that hole in aluminum that will hold 25psi?
