Lower Ic piping
Old Oct 25, 2010 | 10:38 PM
paintballerr78's Avatar
Lower Ic piping
Which brand of lower ic piping would you guys recommend? I see dejons cost around 150 with the coupler upgrade and then zzp's lower ic piping cost around 220...If i buy zzps do i need to buy the maf pad/block off/extension
I have a dejon hotside pipe with tial bov
Old Oct 26, 2010 | 05:47 AM
chudson91's Avatar
i no clear image sells them for 160 powder coated and with tbolts plus you get the turbo block off and the maf block off.
Old Oct 26, 2010 | 06:28 PM
tom.g's Avatar
I've been thinking of doing the lower IC pipe for a while now. Can anyone confirm if you have to remove the bumper to acess the pipe or not?
Old Oct 26, 2010 | 06:32 PM
blk06ss/sc's Avatar
go with clear image
Old Oct 26, 2010 | 06:34 PM
116Fanatic's Avatar
Dejon..
Old Oct 26, 2010 | 07:18 PM
celicacavy's Avatar
I have the CIA charge pipes and all I had to do was jack up the passenger side of the car to get the cold pipe to go in properly
Old Oct 26, 2010 | 07:34 PM
Supercharged Guy's Avatar
I have zzp's lower and let me tell you it isn't easy to put on but I'm sure you will be fine
Just a lot of moving around the pipe and making it fit right but besides that its not rocket science
Theres not a lot of room down there
With the bumper off, it would be a lot easier
So to answer your question NO you dont have to remove the BUMPER!
Old Oct 26, 2010 | 09:32 PM
kidcrash603's Avatar
I've got the Dejon. It installed in like 10 minutes without even jacking the car up. What Kyle (supercharged guy) isn't telling you, is that it took 3 of us over 2 hours to install the ZZP lower pipe even with jacks.
Also, there's no need for the upgraded couplers or even t-clamps if everything is installed correctly.
I've been running base couplers and worm clamps on 25psi for over a year, never had a blow off.
Old Oct 27, 2010 | 01:42 AM
whyyoumadson?'s Avatar
doyou want to run the bov the correct way? then yes you need to relocate the maf....end of story.
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
