Lower MAP bolt spec
Lower MAP bolt spec
Mine looks like hell, and I can't find the other bolt which I'm no longer using since I have the 3 BAR sensors. Anyone have the bolt spec handy? I know it's a self tapping bolt, but I'd like to have a new one on hand before I pull it, again.
This is the only reason I would ever want to replace the lower charge pipe. I hate that we're screwing into untapped plastic.
Its not really self tapping, its just a machine bolt. Go to lowes and take the charge piping with you. I did that when I had my hahn piping and it didn't come with bolts for the map sensor.
Yeah, it has the cutting tip on the first few threads so I suppose it could be classified as a self tapper but I think they call it a machine screw because the tip isn't really pointed or maybe just an automotive screw.
It's not a machine-bolt. It's a metal screw, going into a plastic pipe. Cheap crap, but it works. The original screw doesn not have the self-tapping sheet-metal end on it, so I bought this screw to match it exactly.
