LT4 Fuel Pump
Old Aug 29, 2017 | 08:03 AM
mongorat427's Avatar
LT4 Fuel Pump
Done. tuning the Balt with the 2017 LT4 fuel pump. She runs unreal right to redline but now I have to figure out how to control the ungodly torque steer. Go to my facebook page for more info Jeffrey Nelson Reiland
Old Aug 29, 2017 | 08:32 AM
hawkssoccer11's Avatar
well then i guess im screwed because i dont have facebook! damnit jeff!! how was the install and such???
Old Aug 29, 2017 | 08:54 AM
Im on vacation in Arizona so you can call at 412 915 3183
part of one of my logs
Old Aug 29, 2017 | 09:59 AM
Old Aug 29, 2017 | 12:27 PM
zeeky420's Avatar
I want this but with a pre bent line is this possible ?
Old Aug 29, 2017 | 07:12 PM
I made a jig to bend them so I have a few ready
Old Aug 29, 2017 | 07:14 PM
zeeky420's Avatar
I'll hit you up
Old Aug 29, 2017 | 08:39 PM
63 Nova SS's Avatar
Nice! Does this eliminate the need for the bigger fuel lobe cam? Thanks for doing this jeff.
Old Aug 29, 2017 | 08:50 PM
It was actually set up on the fuel lobe cam
Old Aug 29, 2017 | 09:12 PM
Kickbutts228's Avatar
I'm new to the LNF platform what is the difference in the LT1 VS LT4. What makes it move more fuel?
Old Aug 29, 2017 | 10:00 PM
The LT4 pump is about 33% larger and runs up to 2900psi. Lt1 runs 2000psi
Old Aug 30, 2017 | 11:52 AM
double clutch's Avatar
So this is a direct bolt on besides the line? Mounting point is the same?
Old Aug 30, 2017 | 05:26 PM
Omiotek's Avatar
It uses an adapter which is a direct bolt on.
Old Aug 30, 2017 | 06:27 PM
IM ALSO WORKING ON A REVISED ADAPTER WHICH WILL CLEAR SPECIAL INTAKE MANIFOLDS. Should be ready soon
Old Aug 30, 2017 | 07:15 PM
On vacation in AZ untill the 12th
Old Aug 30, 2017 | 09:10 PM
63 Nova SS's Avatar
Enjoy it!
Old Aug 30, 2017 | 09:30 PM
Omiotek's Avatar
Send me for test fitting while I have 2 of the sheet metal manifolds available
Old Aug 31, 2017 | 09:28 AM
Awesome, I am definitely interested. Are you running opels, or stock injectors?
Old Aug 31, 2017 | 09:44 AM
63 Nova SS's Avatar
Can't imagine he is running anything other than opels. I'm wondering if the LT4 pump will feed enough e47 on opels for a quick spooling turbo like a 6758 without the fuel lobe.
Old Aug 31, 2017 | 10:02 AM
I have no issues now down low with stock injectors, stock cam, and e47. I did have issues up top around 6.5k+ tho, when my boost was 30-31. I think I am 27-28 right now and am fine.
Old Aug 31, 2017 | 03:41 PM
From what I am seeing, these run about $1000?
Old Aug 31, 2017 | 03:55 PM
Mine was $850 from dealer. Im running a 7163 with no issues and have my limiter set at 6900. My last mod will be a Quaife 6 speed conversion
Old Aug 31, 2017 | 05:11 PM
umrdyldo's Avatar
For only $1,500 you can get another 10% flow compared to the LT4 pump
Big Bore Direct Injection High Volume Fuel Pump For GM Gen V V8 Applications
It's just money, right?
Old Sep 1, 2017 | 03:50 PM
cant take it with ya
Old Sep 28, 2017 | 03:28 PM
red_bolt_06's Avatar
where can you buy the adapter's from for the pump
