MAF sensor FIX!?
Old Jul 26, 2011 | 12:16 PM
beast10007's Avatar
MAF sensor FIX!?
ok I have not changed mine because I have the GMS1 and dont want to put it back to stock and have gm reflash me. But I have cleaned it everytime I do that its fixed for a few weeks then 5psi. so I was thinking there must be a lot of oil in my intake manifold and charge pipes and would it help to clean them? before I try this I wanted to know if anyone else has done this.
thanks,
Old Jul 26, 2011 | 12:17 PM
Projekt's Avatar
GMS1 is a upgraded MAP sensor. Not MAF sensor. I am currently going through the same battle.
Old Jul 26, 2011 | 12:19 PM
beast10007's Avatar
ok yea I clean the upper and lower everytime I get the problem I can c oil on both
09SS's Avatar
The MAF sensor is in the air intake. The sensor in the charge pipe is a TMAP I believe.
Old Jul 26, 2011 | 12:22 PM
beast10007's Avatar
gotcha thanks for clearing that up lol....anyways do you guys think this will fix my problem?
Old Jul 26, 2011 | 01:14 PM
dayhoff35's Avatar
clean maf, check for boost leaks. Getting any codes?
Old Jul 26, 2011 | 01:30 PM
beast10007's Avatar
no codes I will also get a flutter when I let off when this happens.
Old Jul 26, 2011 | 02:26 PM
dayhoff35's Avatar
have you checked for a boost leak check ic pipe connections
Old Jul 26, 2011 | 04:57 PM
beast10007's Avatar
yes, although I have a CS intercooler I have been told then are more likely to crack....should i make a boost tester
Sl0wbaltSS
Nov 21, 2018 11:11 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
