Major Fuel Pressure Drop on WOT
Old Jun 20, 2012 | 11:48 PM
  #76
Frogstofall's Avatar
Originally Posted by Matt M
...Frogs- how much gas do you think you had left in the tank when you switched back to E47? The first fill-up can be skewed a lot more than you would expect, putting your E percentage pretty low. You also might have had a higher % ethanol in your E85 last time. We have measured as high as 92% ethanol in E85 from Mobil.
Hi Matt. I would say less than 1 gal left in the tank b/c it was dinging me LOW FUEL for 2 days. It was practically stumbling if I took a turn too spiritedly. When I put the 2 gals of E47 in, the gas tank level marker went to a hair slightly above the first white mark which according to my calcs is approximately 1.8ish gals.
Unfortunately, I don't have one of those nifty Ethanol tester thingies. I need to get one b/c the variance in Ethanol content between the 2 or 3 gas stations I have to use is really messing with my trims at times.
I'm not calling this fixed yet until I'm dialed back in with zero or very very minimal rail pressure drop. I will report back or some of you may hear me complain at CED tomorrow through Saturday.
Old Jun 21, 2012 | 12:52 AM
  #77
CCrunner84's Avatar
Now if only we could figure out why my car seems to have fuel related gremlins lol...
Old Jun 21, 2012 | 01:14 AM
  #78
40rty's Avatar
795161 Alcohol Tester
Hey Matt, will these surfice for testing the ethanol at our gas stations?
James, where you go BRA!!
Old Jun 21, 2012 | 06:47 AM
  #79
We'll get it.
That looks like the one I've seen!
Old Jun 21, 2012 | 07:31 AM
  #80
09CobaltSS1's Avatar
This is the one that I use personally.
Quick Fuel 36-E85 Quick Fuel E85 Carburetors
Same concept as the one 40rty posted though. Simple to use, super cheap, and just takes the guess work out of making accurate blends.
Old Jun 21, 2012 | 07:44 AM
  #81
40rty's Avatar
What's the scale on that one? The link I posted, it only goes to 85. I'd like one that is scaled to 90-95%. Can't make it out in the picture do I see 90%?
Old Jun 21, 2012 | 07:48 AM
  #82
The labeled range is 70-100% (70, 75, 80, 85, 90, 95, 100) on this one. I made mine so it measures down to 50% though so I can get as close to 47% mark as possible
Old Jun 21, 2012 | 08:24 AM
  #83
FrossB's Avatar
Thread Killer
Not sure if this would narrow anything down but, have you tried accelerating thru the rpm range slowly (no or little boost) and see if you have any stumbling issues or fuel pressure drop? different fuel needs when there is no boost. just a thought
Old Jun 21, 2012 | 12:45 PM
  #84
40rty's Avatar
Awesome! Great find! I'll order that one then since the one I posted only goes to 85%. Thanks
Old Jun 21, 2012 | 01:11 PM
  #85
FasterIsBetter's Avatar
He said its not doing it now. Weird eh?
Old Jun 21, 2012 | 01:41 PM
  #86
Matt M's Avatar
Yes, that is similar to what I have been using. Ours has been pretty accurate when we measure right out of 55 gallon drums.
That's the kind that we have.
Old Jun 21, 2012 | 04:04 PM
  #87
raver0789's Avatar
Not sure this is related. A weird thing happened to me. I was just cruising at 60km/hr and my fuel pressure dropped out of nowhere, i wasn't on it or anything. It caused the car to go lean, my aeroforces all lit up warning me. I turned the car off, stopped it. Started it again. Worked like a champ. On my way.
Old Jun 21, 2012 | 04:14 PM
  #88
40rty's Avatar
What tune do you have? Do you have software where you can see what the car is doing whille WOT? Or normal driving?
Old Jun 21, 2012 | 10:38 PM
  #89
Chevycobaltss3's Avatar
LOL.. james went to go pick up parts 3 hors away for the vr6 build hes doing lol!!!
Old Jun 22, 2012 | 07:22 AM
  #90
40rty's Avatar
Modifying a VW? Shame on you. 12v or 24v?
Old Jun 22, 2012 | 11:10 AM
  #91
12v obd2 of course .
Old Jun 22, 2012 | 11:30 AM
  #92
40rty's Avatar
Force inducted or N/A? One of the best sounding motors of all time. Good luck for tuning though. Hope you paid for maestro as that's the only
elf tuning solution kfor stock ecu and even then its not that good. What I would do is get a AEM or standalone and tune it that way. Its what I plan on doing for my GLi.
Old Jun 22, 2012 | 02:52 PM
  #93
SSlobalt's Avatar
Old Jun 22, 2012 | 03:19 PM
  #94
8:5.1 .. You know what's happening. Tuning wise it's gonna depend on my plans on what setup. Cuz no matter what I will be tuning it. I can get the ECM chipped and then use the stock ECM as a piggy back type system. Sorta like a hptuners setup...
I'm still pondering, it's my wife's car
Old Jul 1, 2012 | 06:59 PM
  #95
As promised, a little update. Car still feels great and fuel pressure is holding strong. I shot a quick little video of a few pulls on 26psi. I think I'm gonna have James increase it back up to 27psi and speed up the ramp a little to see how she takes it...
BNR2871 on Cobalt SS - YouTube
I did shoot some video of the old log showing the huge fuel pressure drop but the video is super blurry so I will have to figure out another way and upload it here later on.
Old Jul 1, 2012 | 07:47 PM
  #96
CCrunner84's Avatar
Looks good, and damn do we need some rain!
Old Jul 1, 2012 | 08:15 PM
  #97
Thanks. Yeah we do! Its so dry!
Here's the fuel pressure vid I meant to post earlier. Got it sorted out...
Cobalt SS Fuel Pressure Drop and Fix - YouTube
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
