MAP code's with hahn intercooler pipeing
me and another cobalt installed hahn's intercooler pipeing a week ago and now we are booth throwing map codes does anyone have any ideas of what it would be. its throwing p0107 MAP sensor circuit low voltage
map. it also says system performance
the other guys map was installed the wrong way but mine is on right but we are throwing the same codes
Last edited by supermantxz24; Jan 4, 2009 at 07:35 PM. Reason: Automerged Doublepost
Since its a pressure sensor, orientation doesn't matter.
Are you still on the stock intake? I think i've seen that cel on some solstice's before, but that's after they got an intake that was sized incorrectly around the maf or moved its location farther from the filter.
i have hahn piping but with his catback and PPC tune, no codes over here, well over 500miles since install as well. are all your hoseclamps lined up and tightened properly? did you get the tbolt clamps?
It's not Stevo's tune.... I put that same tune in a buddies car... and got no such code!
And NO he doesn't need HAHNs tune... give it some time it will relearn any issues you have! We put a short ram on a buddies car, through that code eventually went away!
I'm the other car with the codes and we have access to HP Tuners and dropped the stock tune on my car and it still tossed the code. I'm going to be pulling the cold side off to take a look and make sure every thing is still on good.
OK, I pulled the cold side off last night and the sensor on it (I'm guessing that is the MAP from post on this) was on good and looked fine. I put it back on and still have the code. (I did flip it back around just in case)
One question I have that I hope someone can help me with is when I read the MAP KPA with my Interceptor Gauge it just gives me a 0. Also when we looked at it with HP Tuners the other night it did the same thing. Could the sensor go out on both of us? or dose that sensor not show you anything? Still new at the whole tuning world.
Thanks for any help you can give.
Waiting for GM tune or going w/ Hahn (since I can put it back to stock for dealer visits)
Its the MAP sensor, not the MAF. There is no direction on a pressure sensor. Only the Mass Air Flow sensor. His code is the Manifold Absolute Pressure sensor.
Check your wiring - make sure some wire didn't get pulled loose when you were installing the piping. You should be getting some sort of reading from that sensor!
Ok, after a good bit of research I have found that the LNF has a TMAP (on the cold side pipe) and a MAP (on the intake manifold). I know the TMAP has to be the IAT2 temp reading but Im not sure what it also reads. Any one knows if one or the other has a problem if they both would cause the same code? Im try to narrow this down and its just getting bigger lol.
If it is the MAP sensor that you talk of that is on the intake manifold, but i have had another cobalt come into the shop with the same codes, the sensor was bad, you might start to notice a slight misifre.
