MAP code's with hahn intercooler pipeing
oh i was jsut throwing it out there.. i have both the charge pipes and intercooler on order... group buy FTW!!!! long time comming as well been waiting since november for this ****
No misfire problems as of yet, but after a lot of checking wires and other stuff it had come down the sensor can be the only thing left that could cause the problem. Also I keyed it down to the one on the intake manifold as the boost level the computer can see is not reading and the MAP KPA is reading 0. I'm working on getting a new one as I hate to have my car not having everything running right. And at this point with everything I have done I don't want to have to deal with the dealership.
So i'm trying to get a MAP ordered and found out that they are on "national backorder with GM". I got a connection that is looking to see if he can get one for me, but if not is their some other maker or any idea's on what I can do.
See if a stage 1 (2?) HHR will give me their old MAP sensor? Any one know if it's the same part number (12592016)? Sorry just typeing out loud here.
robs car is also having this problem. just threw the code today. been stalling on him. idling strange. mine hasnt had a problem yet. ive also not been going crazy on the car. after letting the car warm up i move out from there. ive had maybe a slight idle bounce here or there but nothing major.
Well similar problem with my Piping deal now. Installed the Hahn Piping, Hahn IC and put the upgraded BPV Spring in. At first start up it just stayed idling at 1500-2k rpm, basically got to op temp them I shut it off. Fired again, Idle stuttered a bit but settled. But then at the same time I threw a P0238 - Turbocharger Boost Sensor 1 Circuit High Voltage, and a P0098 - Intake Air Temperature Sensor 2 Circuit High. Cleared them with the Dashawk. Drove the car and only 5.5psi boost and some good lag. Got home, shut it off, refired and the codes came back. Right now no aftermarket tune is on the car. What does everyone think?
dude you have the most random posts in this thread. a hahn PPC tuner is not going to majically fix all his issues. there is obviously something wrong with his MAP sensor
if he frayed the wires.... when changing something out.. then yess.... then riddle me this batman: how is it i have the SAME EXACT CAR AND SAME EXACT PARTS and NO PROBLEM????
Yeah, I haven't thrown any MAP codes yet, unless it's part of that IAT2. Also, I haven't switched to an external BOV. Just put the upgraded Spring for the stocker from Dejon. I don't think I have any boost leaks either. I think I might put the stock spring back in and see what happens.
As for that $250 tune, that the trifecta deal?
So that 1 little sensor must be fragile on those pipes. New technology blows. Of course, I bet it's back ordered. Doesn't matter, still cold as hell here and the help I had (my brother) just left. We used the shop I work at to do it. So for now she'll just sit till it gets warmer.
Ok, then the one on the tubing is the IAT2. It is one of my CEL's. The MAP seems to be working, I can see the different kPa on my Dashhawk. My other code, P0238 - Turbocharger Boost Sensor 1 Circuit High Voltage, wonder if that is an issue with the upgraded spring and no tune. Always something, I don't want to have to take all this stuff off again.
