MAP SENSOR p0107
Old Oct 13, 2009 | 04:13 PM
pt5457balt's Avatar
Originally Posted by drewbroo
My tune is only on when I am in comp mode. Its stock boost levels otherwise. Also I was hp tuned for 10K miles at 22.5 PSI, no problems there either. Its just a bad run of sensors.
I've seen several pop on a car with a stock tune. Something in the no-lift shift process was causing it.
Old Oct 13, 2009 | 04:26 PM
Stamina's Avatar
Originally Posted by pt5457balt
My friend has been through almost, if not more, 15 map sensors.
The dealership even tuned his car to produce LESS boost that factory, and it still blew two sensors.
The problem is not with boost. Unfortunately, they haven't figured out what the problem is either.
His repair bill and rental fees have probably exceeded what the car is worth by now.
Stupid gm.
Man, they should've Lemon'd that thing by now. It would've been in the best interest of both him and GM it sounds like.
Several people, including me, have witnessed what is best described as an "NLS Spike". In my case, for instance I can go from 22 to 25.5 or something and back again during an NLS. Something the engine/ECU is doing is causing some sort of artificial load somehow or perhaps letting up on the wastegate a bit during the shift to keep everything prime for after the shift.
This sudden high spike may be at least part of what's taking out these MAP sensors.
Old Oct 14, 2009 | 12:22 PM
tlake84's Avatar
I'm on my third one as well. Hopefully the rumor is true, that its just a bad run of them...
Old Dec 11, 2009 | 01:38 AM
SaleenFreak's Avatar
will the dejon MAP-Regulator help with this problem??????
Old Dec 11, 2009 | 03:03 AM
VinceTrifecta's Avatar
No.
There was a defective run of MAP sensors that got installed on apparently only Cobalts. People running stock boost levels have this problem, too.
You must get the sensor replaced under warranty.
Old Dec 11, 2009 | 03:13 AM
RBC's Avatar
RBC
Originally Posted by VinceTrifecta
No.
Well I got mine back from the dealer after they put a new computer and map in it. I haven't had a chance to get your tune put back on the new computer.
Chad
Old Dec 11, 2009 | 11:53 AM
Chad
Weird they replaced the computer, too - that's the first time I've heard of that.
In all the cases I've seen of this problem - and one customer did manage to catch the actual failure it in a datalog - the MAP sensor is just going along reporting its pressure and all, and then all of the sudden it just goes to 0 kPa.
Old Dec 11, 2009 | 12:44 PM
BYT*SS*TURBO's Avatar
Ive been running 28-30psi over 10K miles now, same OEM sensors, its not the boost level. 2 people I know have constant MAP sensor issues, different tunes/psi levels etc..
Old Dec 11, 2009 | 06:53 PM
RBC's Avatar
RBC
I believe that was me.
Old Dec 11, 2009 | 10:21 PM
lifeguard15's Avatar
Anyone had problems with the upgraded sensors with GMS1?
Old Dec 11, 2009 | 11:38 PM
  #36
pookie025's Avatar
mabey we have to get the stage 1 sensor???
Old Dec 12, 2009 | 09:51 AM
  #37
The stage 1 sensor just shows extended range...
Old Dec 12, 2009 | 09:10 PM
  #38
Married w/children's Avatar
Just popped another, this makes 3 in 6k miles...piece of ****,!!! however I do suspect NLS is involved in some fashion with a flawed MAP.
Old Dec 12, 2009 | 10:32 PM
  #39
No.
Last time I was tuned for about a month and right before I got the code P0107. I WOT on a steep hill, I wanted to fly by and slow slow driver, when I got home I turned off the car, waited a couple of hours and turn the car back on and bump the code popped on.
Old Dec 13, 2009 | 04:35 AM
  #40
oopsitouchedmyself's Avatar
Chad
that's cause the repair printout the dealers have says to replace the computer if the map sensor voltage readings read anything or nothing lol it's a typo on GM's part and your dealer couldn't put 2 and 2 together to call them up and ask what was up. all they needed to do was replace the map sensor.
Old Dec 13, 2009 | 02:24 PM
  #41
RBC's Avatar
RBC
I told them there was nothing wrong with the computer and to replace the map and they just blew it off like I didn't know what I was talking about.
Old Dec 27, 2009 | 04:29 AM
  #42
HB_SS/TC's Avatar
So if the map sensor goes out it'll throw a code p0107? Or are there other symptoms of it going out?
Old Dec 27, 2009 | 08:08 AM
  #43
boosted4dr's Avatar
The repair states it and its more money for the dealership and techs
Old Dec 27, 2009 | 12:19 PM
  #44
Yep. That's the only symptom. The car otherwise seems to run fine (from what I've been told - I've never run into it on my car)
Old Dec 27, 2009 | 06:02 PM
  #45
Terminator2's Avatar
Normally the car will run really rich once it goes out. It no longer has the ability to properly calculate cylinder airmass and thus the amount of gasoline to be injected. The car will normally smoke and will feel "lazy".
Old Jun 3, 2010 | 08:26 PM
  #46
fredds-turbaltSS's Avatar
is it worth it to get the 3bar MAP?
Old Jun 3, 2010 | 09:26 PM
  #47
Well knock on wood mine hasn't gone out in awhile, this on has lasted 5000 miles, would definately consider the 3 bar if you are tired of the CELs and rough starts. I still think that NLS has something to do with wrecking the corrupt MAPs
Old Feb 20, 2011 | 02:56 PM
  #48
Gremlin85's Avatar
Found this thread and it answers a lot of my questions.
THE SEARCH BUTTON DOES WORK! OMGGTFOTMITGFT!!!!!
I threw this code yesterday. All was fine until I NLS making a video. Code came on after I shut the car off and went back out later.
Old Jul 21, 2012 | 02:08 AM
  #49
Validater's Avatar
Hate to revive an old thread, But I'm about to diagnose a map sensor for a friend tomorrow.
Anyways on to my point, has anyone found the cause for this? other then just blaming a humongously bad batch. IE boost spike, or spike in combination with engine bay heat wearing down on the sensor till it calls it quits.
Old Apr 21, 2015 | 09:14 PM
  #50
Tohken08's Avatar
So I'm having the Po107 and misfires on all cylinders and I was just wondering, when you guys are talking about replacing map sensors, are you talking about the upper one or the lower one?
