MAP SENSOR p0107
Old Aug 12, 2009 | 12:01 AM
SaleenFreak's Avatar
MAP SENSOR p0107
well need help.... my map sensor keeps blowing up( not literally ) i'm currently tuned to have about 25 psi only on competetive mode. what options do I have to prevent my next map sensor from getting damage
Old Aug 12, 2009 | 12:04 AM
RYRO14's Avatar
so do you have the infiniboost tune from trifecta? The only thing you can do is play stupid and keep going to the dealership for warranty, or stop boosting so god damn much
Old Aug 12, 2009 | 12:20 AM
Gabi's Avatar
TE LO DIJE!!!!!!!
hahahahaha
Old Aug 12, 2009 | 02:19 AM
lecznar1's Avatar
do u have an intake? try turning ur boost down
Old Aug 12, 2009 | 11:17 AM
Terminator2's Avatar
Turn the boost pressure dowm to 22 psi then you will not blow sensors like that.
Old Aug 12, 2009 | 01:28 PM
VinceTrifecta's Avatar
This is a run of bad sensors from GM.
There's another LNF owner I know of, who had the dealer turn the boost down to 10psi and it still "blew" the sensor out. He's been through about 20 of them already.
Old Aug 12, 2009 | 06:13 PM
wrecklessboost's Avatar
im on my 5th one! there outa control
Old Aug 12, 2009 | 10:05 PM
Gabi's Avatar
he is not the only one here with that problem
so i think it is the boost
Old Aug 12, 2009 | 10:30 PM
Cougarguy's Avatar
Broke is broke...
Old Aug 12, 2009 | 10:50 PM
Married w/children's Avatar
Mine blew... GM ha a service bulletin out on these. Not your fault, they will fix it under warranty
Old Aug 13, 2009 | 02:26 AM
ok, no i have no intake, not planing on having one (just a k&n drop in)
opion, my tuner friend was telling about adapting an aftermarket 3 bar mapsensor and tunning for it, since it composes of a signal wire a power wire and ground.....and i was thinking of buying the dejon map sensor regulator....what do yall think?
Old Aug 13, 2009 | 11:13 AM
tlake84's Avatar
I just blew another one as well... First one went 10,000 miles on the tune and the one after that went about another 10-12,000 miles...
Old Aug 13, 2009 | 11:16 AM
tlake84's Avatar
I think it maybe the problem of adding an intake AFTER a tune...
Old Aug 14, 2009 | 07:09 PM
sheldon729's Avatar
i have been tuned for a while with evey bolt on besides turbo and manifold and have not fried one yet. knock on wood
What 3 bar sensors come in the gm stage kit is one the map?
Old Aug 14, 2009 | 11:26 PM
These are a bad run of sensors, that's all.
Old Aug 17, 2009 | 09:51 AM
tlake84's Avatar
Link? TSB#? I'd like to see it
Old Aug 17, 2009 | 02:39 PM
buckleybum321's Avatar
part number?
anybody know the part number for the Map sensor? I just got the same code and am going to order one from gmpartsdirect.
Old Aug 17, 2009 | 03:21 PM
pt5457balt's Avatar
My friend has been through almost, if not more, 15 map sensors.
The dealership even tuned his car to produce LESS boost that factory, and it still blew two sensors.
The problem is not with boost. Unfortunately, they haven't figured out what the problem is either.
His repair bill and rental fees have probably exceeded what the car is worth by now.
Stupid gm.
Old Oct 11, 2009 | 06:40 PM
Black08SSTC's Avatar
I just had the code P0107 come up at the track, tuned 25lbs spike, but im going to replace it and see what happens. Its just the map sensor right?? no harness??
Old Oct 12, 2009 | 11:26 PM
09whteSSpssssh's Avatar
Im on my third all have happened while NLS'ing while tuned, at least in my case. Its starting to get old fast.
Old Oct 12, 2009 | 11:59 PM
drewbroo's Avatar
mine went out a few weeks ago, I have been tuned for over 15K miles, and it happend when I started my car one morning.
Old Oct 13, 2009 | 12:13 AM
pt5457balt's Avatar
That means it happened however you were driving last night.
I just had mine go out, and i know it was from boost spiking.
Old Oct 13, 2009 | 12:20 AM
drewbroo's Avatar
I had not had the car in comp mode the day before, i also lost one when I was stock at 2300 miles.
Old Oct 13, 2009 | 01:12 AM
pt5457balt's Avatar
What does comp mode have to do with it?
mine lasted through almost 27k miles, 21k of that was tuned to either 21psi after just a reflash or up to 26-28psi here recently with the turbo swap.
Old Oct 13, 2009 | 02:23 PM
drewbroo's Avatar
My tune is only on when I am in comp mode. Its stock boost levels otherwise. Also I was hp tuned for 10K miles at 22.5 PSI, no problems there either. Its just a bad run of sensors.
