Map sensors stg1 $44
Old Apr 21, 2010 | 04:30 PM
silverbullet08's Avatar
Well after a wild goose chase that lasted about 4 hours today i finally got a hold of some Gm stage 1 sensors. I got them straight from the dealer and came out to like $44.50 after tax. Now i just need the harnesses to finish it off. Only problem is GM charges $114 for the harnesses a piece !! so does anyone have a picture of what wires you you splice together? i may make my own plug and wire it my self. Any help is appreciated.
Old Apr 21, 2010 | 04:43 PM
northvibe's Avatar
Install pdf:
http://www.crateenginedepot.com/pdfs/frsp19212711.pdf
sensors: $16.x a piece
http://www.crateenginedepot.com/stor...P2533C196.aspx
harness: $87.x a piece
http://www.crateenginedepot.com/stor...P2594C196.aspx
Old Apr 21, 2010 | 04:48 PM
crypticscifer's Avatar
I found the adapters cheaper.
Old Apr 21, 2010 | 04:50 PM
koch1ar's Avatar
ouch
Old Apr 21, 2010 | 07:05 PM
dinas29's Avatar
So with those connecter and harness without GMPP tune but a hp-tuner, It will be better for performance?
Old Apr 21, 2010 | 07:14 PM
Where at? i have looked everywhere. Post a link!
Old Apr 21, 2010 | 08:05 PM
peachpuff's Avatar
Wont work, you need the gmpp tune so the sensors are read properly.
Bare connector http://www.bmotorsports.com/shop/pro...oducts_id/1625
Connector with pigtails http://www.bmotorsports.com/shop/pro...oducts_id/1626
Old Apr 21, 2010 | 08:14 PM
hiltu's Avatar
subscribed. Dinas29, if im correct, this map sensor will allow you to log boost above ~22.5PSI, its a 3 BAR sensor vs. 2.5 BAR. Right now when i boost about 22.5psi, my datalog just goes flat at 22.5 until i go below 22.5 again. The performance is really gained by the flash tune.
Peachpuff, the tune is NEEDED? that seems weird in order for the sensors to work
Old Apr 21, 2010 | 08:46 PM
peachpuff's Avatar
Hptuners won't read over 22.5psi, something to do with some pid limitation. However if you take the 5v output from the sensor and send it over to the mpvi pro interface you could log the raw voltage and convert it to boost.
Yes the tune is needed, there are a couple gmpp tunes floating around on the hptuners forum.
09CobaltSS1's Avatar
You still will not be able to log above 255kpa, however the tuning ceiling of 255kpa is no longer there via tuning for sensor voltages . The logging is limited by the software, not the hardware in this case.
I don't mean to answer for peachpuff, but yes the gm stage 1 tune is needed to utilize the new 3 bar maps and then HPTuner can tune on top of the new gm tune configuration
edit: apparently peachpuff came back on while I was typing... lol
Old Apr 21, 2010 | 09:15 PM
northvibe's Avatar
ya thats fine, but Tom at CED is a supporting vendor and treats us right...well me anyway. So I like to support him. You can always ask him if he can price match...... If its that stupid ass gmparts direct or whatever they rape you on shipping.
Old Apr 21, 2010 | 10:10 PM
Jbowman62's Avatar
off topic does anyone know the part # for the wideband 02 sensor
Old Apr 21, 2010 | 10:15 PM
Geoff's Avatar
everything you need http://www.performanceautowerks.com/...oducts_id=1712
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
