May have solved 100% E85 on LNF puzzle
Old 03-08-2011, 03:42 PM
  #126
drewbroo's Avatar
My question is, would a nearly stock LNF need a pump upgrade if say they are only looking for 310-320WHP?
(I am guessing less WHP demand => less fuel damand => less fuel pressure needed) Just curious if this can be acheived with the TF tune. I am willing to guinnea pig for this also
Old 03-08-2011, 03:48 PM
  #127
VinceTrifecta's Avatar
This I need to experiment with some more. I drove my car about 100 miles yesterday, but did pop the P0087 code after a 1st, 2nd, 3rd, NLS to 4th pull. My car is bone stock other than the tune. I wasn't monitoring fuel rail pressure stuff so I don't know exactly what happened, but I've seen other LNF cars (mostly roadsters doing 5th gear pulls) hit P0087 even on gasoline.
Old 03-08-2011, 03:53 PM
  #128
slowbalt84's Avatar
Just out of curiousity were you about or below a quarter tank of gas? I noticed that when i am below 1/4 tank of gas and go WOT i pop P0087 quite regularly but if i am above 1/2 tank of gas it never happens. It seems as though fuel pressure is not as strong under 1/4 tank of gas.
Old 03-08-2011, 03:55 PM
  #129
drewbroo's Avatar
My coupe has hit it before with the 50/50 mix. Again, I am willing to try it out if you wanna send a tune my way.
Old 03-08-2011, 03:56 PM
  #130
No, I had filled up 100% on E85. By then I'd been through about 1/4 tank, so I had around 3/4 left.
The P0087 can be caused by several things. It basically means the actual fuel rail pressure is too far below the commanded rail pressure. This could be due to low pressure pump supply issues, clogged lines, or simply maxxing out the high pressure pump / system as ZZP said. I didn't have a chance to investigate the specific cause on mine, yet.
Old 03-08-2011, 04:00 PM
  #131
drewbroo's Avatar
When I swapped my Saab over to E85 my fuel filter got clogged..... mainly because it cleans all the crap out.
Old 03-08-2011, 04:01 PM
  #132
The question I've been mulling over is this: is it better to keep the rail pressure lower and advance the injection timing (and lengthen the pulsewidth) or to keep the rail pressure cranked up? I guess the volume of fuel doesn't change from one scenario to the other, but perhaps the workload on the high pressure pump may be lower if it has more time to inject the fuel rather than trying to make it happen really quickly, at really high pressure.
EDIT: I suppose the best thing to do is to try both and see which results in a more stable fuel rail pressure...
Old 03-08-2011, 04:02 PM
  #133
gmtech16450yz
Guest
Posts: n/a
Somewhat to my surprise, nobody has approached us directly about obtaining what we've uncovered in the Bosch ECMs. And it's not for a lack of trying to get this information, either.
Weird, if I was running HPT or EFILive I would at least entertain the idea of working together for the same goals. If I were you I probably would have tried to work a deal with them also.
Your strengths are obviously more on the software end since that's your background, I would think you would prefer to concentrate on doing that more than actual tuning. As I'm sure you are well aware of, tuning comes with liabilities and constant support that can be a pain in the #ss. With you providing the software and an entire community of tuners out there experimenting with the tables we'd all progress WAY faster. I know I for one have figured out stuff in the EFILive and HPT software that the guys that made it didn't know or understand what it could mean or how it could be used. You've been a huge help to the LNF community, as HPT has been and now (maybe) EFI will be too. The possibilities of progressing further would be huge if all the LNF tuners were looking at what you see on your computer.
Just a few thoughts, thanks for your reply and acknowledgement, I appreciate that.
Old 03-08-2011, 04:05 PM
  #134
slowbalt84's Avatar
This is really good news for big turbo guys if the fuel pumps can support it.
Old 03-08-2011, 04:08 PM
  #135
Omnigear's Avatar
Originally Posted by RyRidesMotox
Hopefully he figures out how to turn creamed corn into fuel... there is a sale on cans of it at the local vons
Old 03-08-2011, 04:12 PM
  #136
rnjmur's Avatar
It also seemed to imply that the problem with injection window size was due to injection carrying over into the compression stroke and that going outside the injection window meant injecting fuel while the exhaust valve was still open causing soot build-up due to an improper combustion.
You definitely don't want to spray fuel while the exhaust valve is open, however it was my understanding of turbo DISI motors that under positive pressure you wanted to keep the intake valve open and continue spraying fuel into the incoming air even when in the compression stroke. Of course the amount of time into the compression stroke that you can do this is based on the amount of air being pushed by the turbo so at higher boost you can contiue to push air and spray fuel longer into the compression stroke.
As for being able to lengthen the injection window, this is good news for bigger turbo setups as well as those wanting to run E85. It is a shame that we can't have an easy one stop shop for all of our LNF tuning needs, though the Trifecta + HPT is close to accomplishing that.
Old 03-08-2011, 04:19 PM
  #137
drewbroo's Avatar
Anyone thought about an inline pump? This might take the strain off the low pressure. I am sure someone had to think about this, just seeing if its been tested.
Amazon.com: Pierburg Fuel Pump: Automotive
Old 03-08-2011, 04:27 PM
  #138
ripped's Avatar
vince what kind of hp gains are we looking at here.
all these hondas down here are running around using e85 as race gas, glad to know we finally have the option
i don't want to thread jack but could we see trifecta evolving the ezflash cable to something like this.with all the maps, and diff fuels you can tune and offer i think a simple handheld device with a couple different tunes on it would work out better then carrying a laptop around everywhere.
just a thought.
http://image.automotive.com/f/tech/8..._held_unit.jpg
Old 03-08-2011, 04:43 PM
  #139
drewbroo's Avatar
just a thought.
or a trifecta droid app would be pretty sweet
Old 03-08-2011, 04:58 PM
  #140
Omnigear's Avatar
oh droid app ^_^
Old 03-08-2011, 05:12 PM
  #141
RoadconeTuning's Avatar
FWIW our local stations in Upstate, SC are all at full 85% ethanol now... i honestly dont think they ever switched the E78 this year and we never get down to E70... i only know about us having true E85 because my friend is building a race car and wanted to make damn sure before tuning it...
Old 03-08-2011, 05:40 PM
  #142
hmm, that's the second time this week I've heard this. ;-)
Old 03-08-2011, 05:46 PM
  #143
HHRSSouth's Avatar
I'm to poor for one of those nice fancy phones, I'm still rolling with the I-touch
Since your no longer with Microsoft, that wouldn't be a problem would it?
Old 03-08-2011, 05:47 PM
  #144
MS3 2 SSTC's Avatar
iPhone app would also be nice
Old 03-08-2011, 05:59 PM
  #145
FF_ace's Avatar
good news im hoping i can run 100% e85 on the 5857 turbo
Old 03-08-2011, 06:20 PM
  #146
08ssedan's Avatar
or a trifecta iphone app would be pretty sweet
Fixed
Old 03-08-2011, 07:26 PM
  #147
cmiller8006's Avatar
Dont think we will be able to get there still. That is ALOT more fuel need than just on the stock turbo. But this will work very well for say race gas and a big turbo.
Old 03-08-2011, 07:41 PM
  #148
Omnigear's Avatar
iphone is 2 **** with its apps , so unless the phone is jailbreak =p
Old 03-08-2011, 07:54 PM
  #149
MS3 2 SSTC's Avatar
Jailbroken with Greenpoison
Old 03-08-2011, 09:21 PM
  #150
PrincessTurbo's Avatar
Originally Posted by Ch1ck3n
Any idea if you'll be able to add support for other proprietary software brands? Sounds like I might be caving and getting the ol' hybrid tune.
We are all going to Have to because HPT is a damn joke ...
Good thing my buddy lives around here with Dealer cable
You really need both IMO ....
Quick Reply: May have solved 100% E85 on LNF puzzle
